db_in_qld's Avatar
Question "Lost" 3rd and 4th gears ('86 930)
Hi, wondering if anyone can help? While driving over the weekend I "lost" (the ability to shift into) 3rd and 4th gears. It feels as though the linkage is loose or disconnected, as when I try to select 3rd, it slots 1st and similarly 4th is slotting 2nd...
Is the problem in the shift assembly (gear stick), or is it where the shaft meets the gear-box selector under the rear seats???
I'm hoping this is a quick, easy and cheap repair/fix i.e. tighten up a bolt... Thanks in advance!
Old 07-24-2005, 07:03 PM
db_in_qld's Avatar
I thought this would be an easy-fix..? Can anyone help??
Old 07-24-2005, 08:30 PM
Information Junky
island911's Avatar
Sounds like a loose or broken shift fork. (?)
Maybe John Walker will chime in Monday. PDT
Old 07-24-2005, 09:13 PM
db_in_qld's Avatar
Thanks Island. The shift fork is located under the rear seats isn't it?? It is what connects the shaft to the gear box and has a pin going through it...
Old 07-24-2005, 09:17 PM
RETIRED
Joe Bob's Avatar
Fork be in the da trans...the shift linkage may have slipped. That's in the tunnel under the carpet behind the front seats.....
2012 ML350 3.0 Turbo Diesel
Old 07-24-2005, 09:23 PM
db_in_qld's Avatar
Thanks heaps man That's kinda where I thought - just haven't looked yet. Get onto it tonight.
Old 07-24-2005, 09:29 PM
