Hole Grommet for Lower Plug Wires???
Does anyone have any suggestions for a hole grommet for the sheet metal hole originally used for the heater hose that I am using to route my lower plug wires?
Most rubber grommets are rated to about 210 deg F. How hot does this area get? |
Tom,
It can easily get to 250°F - 300°F++ during a heat soak or waiting in line at the bank drive-up line ... due to exhaust system and cylinder heat vented right below that area! Go to a commercial HVAC or electrical supply and look for some large snap-in metal plugs. Cut or punch a smaller 3/4" - 1" hole in the center, and seal the plug to sheetmetal, and plug wires to center hole with black silicone hi-temp sealant.
Warren Hall, Jr. 1973 911S Targa ... 'Annie' 1968 340S Barracuda ... 'Rolling Thunder' |
Location: member Central PA Region PCA , Home of the Hershey Swap
Or you could split some heater hose lengnth-wise and silicone it in there for added measure.
regards, Steve
Steve Frequent Pelican Customer 1984 Carrera 3.2 (S. Wong Chip, B&B dual exhaust, Lightened OEM Flywheel, Centerforce Clutch, OEM 930 Rear and Front Sway Away 930 T-bars and sway bars w/OEM susp. bushings,, Turbo Tie Rods, bump steer kit, Adj. Rear Spring Plates, OEM Short Shift, H4s and "City Lights", slotted rotors, 944 Wheels, 225/50/16 and 245/40/16 Dunlop "sneakers," and more 2002 996 TT X50 (H&R Springs) 2002 WRX in WRX Blue Proud Rennlist Charter Member Support and Join Rennlist.com An Expert on absolutely nothin' more than my own opinions! 2002 WRX in WRX Blue |
