Oxygen sensor connection/connector craked
Found out today that the orange connector is cracked on the O2 sensor side. The oxygen sensor itself is still connected but the end of the connector is a bit flimsy. The green wire side looks fine. Can I wrap up the bad end with electrical tape? Or should I try to repair it? Does anyone have a step by step repair instruction? Would this crack cause the O2 sensor relay to begin clicking. I've had this happen lately. Thanks for any and all info.
('81 911SC)Thanks. :) |
I'd disconnect the thing and have someone set your CO to 2.75% - 3.5%.
It will get rid of that cruise surging you probably have. rjp |
I'd like not to worry about it but I'm going to be needing it to pass smog over here in CA. Thanks:) In the event that I need to replace the sensor I would like to have an idea of how to handle the bad connector. My understanding is that it's part of the wiring harness and can't ordered as a seperate part. Really looking for a fix for this. Thanks for the idea anyway.
If your talking about the plastic connector mounted onto the body of the car, mine was cracked. I cut the wire put a spade connector on and did the same with the wire on the O2 side. Funny thing is I keep it disconnected:)
Looks like that would be the easy fix. Thanks Jesset100.
By the way, do you remember the type (size/guage) of spade connections that you used? Thanks.
12~18 gage I think. It's what I had at the time.
| All times are GMT -8. The time now is 11:00 AM. |
