brake diverters (993 brake air scoop) question
Hi all,
I was wondering if anyone makes an aftermarket of this 993 piece. Or, if I have to get one from the dealer, if anyone has the p/n handy, or can tell me where I can get one for less than a dealer would charge. Thanks, all! ![]() Edward |
Platinum Member
part numbers 99334108300 and 99334108400 available from our host (Pelican) for $10.89 each.
Political polls are often to give you an opinion, not to find out what your opinion is - Scott Adams |
Schleprock
Got mine thru Pelican as well.
Whether they help or not on pre-964 cars, I dunno. I put them on my car and my pedal definitely gets softer by the end of the day @ Blackhawk. But since i'm a full-on rookie with only two events under my belt? Probably has something to do with my braking technique, since my buddy (also driving a '87 coupe) has no cooling diverters, probably still has the splash shields, A/C and bumper pads still installed, stock suspension and is running PF97 pads, ATE fluid, Powerslot rotors and A032R hard compound tires with no need to bleed his brakes after driving plenty aggressively for five 1/2 hr. sessions yesterday. He's definitely using almost ALL of the car's available braking and lateral grip. I'm running Yoko ES100 tires, F/R HD/Sport Bilsteins, 22/29 t-bars, heavy RS America seats (with a big 'ol stereo amp under the pass. seat), complete A/C removal, ATE fluid, Ferodo DS2500 pads, no splash shields, 993 diverters and the hub block-off plates to try 'n force the air thru the rotor vanes instead of out the center. I'd bet that one more session may have required a brake bleed. My pedal got quite soft. Never went away completely, but was much softer than the pre-track rock hard pedal.
Kevin L '86 Carrera "Larry" |
Automotive Monomaniac
First of all, they are cheap, even through your dealer (but buy them at Pelican and support this site).
Second, I have them and they help tremendously. I pulled my splash shields, installed the diverters, and I have yet to see fade - even when I push really hard on the track. Now, granted I have 930 brakes that are a bit larger than stock Carrera brakes... I am running Toyo RA-1's and ATE Super Blue fluid. I am using an aftermarket pad that is a good compromise between street/track (I can't remember the name!).
2018 - Porsche 911 Carrera 7MT / 2018 - Porsche Macan 7DCT / 1993 - Cadillac Allante / 2023 - RAM TRX (on order) |
Edward,
For what it's worth, I've used the 993/994 diverters and they really do not offer enough cooling to solve SC/Carrera brake issues. I now use the AJ-USA under a-arm scoops with the hub block off plates. Add that to Carrera front brakes, Hawk Blue pads and Motul 600 Fluid and I don't have soft pedal problems at the track anymore. BTW, that is with street tires. I'm sure if I went back to R rubber I would have issues again.
Gone but not forgotten - 1980 Porsche 911SC w/ -22mm/28mm Torsion Bars | Custom Valved Bilsteins | 22mm/21mm Carrera Sway Bars | Elephant Poly/Bronze Bushings | Carrera Brakes | AJ-USA Brake Cooling | Carrera Oil Cooler w/ Fan | Elephant Strut Brace | Oh, and no ABS or PSM or A/C |
Thanks, all. I appreciate the quick replies!
![]() Edward
993: retired Trackmeister, now daily driver heaven 911SC: resident Trackmeister-in-progress |
I'm installing mine tomorrow night. Let's see some install photos. I've seen ghetto zip ties and some pretty fancy stuff. How's everyone done them?
2022 BMW 530i 2021 MB GLA250 2020 BMW R1250GS |
Deceased: Black '88 Carrera Coupe, Steve Wong and Russell Berry chips, Dansk premuffler, custom MK GT3-style muffler, Magnecores. Al Reed 7 & 8 X 16 Fuchs. Full Elephant Racing suspension, 21/28 T-bars, Turbo tierods, bump steer kit, Bilstein Sports, BK strut bar. Ruf bumpers, 935 mirrors, Carrera 3.0 tail, DasSport bar. '11 BMW 328iX, '18 Nissan Frontier 4X4, '92 Acura NSX. |
Armando Diaz 85 911 Carrera - Track car 01 996 Carrera - For Sale http://forums.pelicanparts.com/showthread.php?s=&threadid=327823&highlight=996 87 944na - Old Daily Driver, now 944 CUP 03 Chevy Avalanche- Support Vehicle 70 Olds 442 W30 Conv- Gone but not forgotten http://www.diazracing.com adiaz@diazracing.com |
Schleprock
Armando,
I agree. Other friends running PF97's seem to have less of a problem than I! Bill Verburg's always said that the Ferodo DS2500's are marginal for track use. I can now attest to that.Here's my scoops.
I'm installing them next week. They will coneside with my AJ backing plates.
The pads I use are PBR/Axxis Ultimate Ceramics. I am very happy with them.
"The PBR Ultimate brake pads feature a special Kevlar® and ceramic-strengthened formula with a high co-efficient of friction and excellent high temperature wear and fade resistance. Designed for ultra-high performance driving and hard-braking applications, PBR Ultimate pad users will benefit with extreme stopping power and high resistance to brake fade at high temperatures, meaning the decrease in friction over repeated heavy duty stops, as the temperature increases, is minimal. PBR Ultimate pads boast a maximum continuous working temperature of 550° C (1022° F degrees). Consistent throughout its operating temperature range, you’ll get dependable, predictable stops time after time while maintaining a solid pedal feel."
