-   -   4 1/2 by 15 fuchs question (http://forums.pelicanparts.com/porsche-911-technical-forum/232799-4-1-2-15-fuchs-question.html)
adomakin 07-25-2005 10:39 AM
A friend has just sold a pair of rare 4 1/2 by 15 fuchs. the person that he sold them to reckons that they are not 4 1/2 by 15's as they measure wider then 4 1/2 inches. he is measuring them from outside edge to outside edge. i was led to belive that fuchs should be measured from INSIDE to INSIDE edge to get a true width measurement. is this true? can anyone help? to make matters worse my friend has been told that some of the real early wheels were not stamped with a part number? true/false?
thanks for your help
klaucke 07-25-2005 10:42 AM
Measured from the inside of the bead to the inside of the bead, not the total width of the rim!
http://members.rennlist.com/1976c38/index.html
adomakin 07-25-2005 11:32 AM
Cheers klauke, problem solved!
