Elgin or Web Cams in 3.2
My engine is getting an early Xmas full rebuild. It was leaking so much oil the EPA began sending me letters. Plus the broken head stud was a constant reminder of potential doom. So after the shop opened it up we decided to do a top and bottom rebuild. Now do I go ahead and get the cams that I've been reading about for the past few days (there are about 250 pages of cam info under the search button) or skip it. From all the posts Elgin and Web seem to get high marks for the price. The car is almost a daily driver, has a MAF system, and will get to see the track again for DE duty now that the head stud is repaired.
BTW, the head stud did not result in any damage even after driving for 3 years. The K&N filter on the MAF seems to have kept the engine clean after 100,000 plus miles. A few rod bearings were scored, pistons were cover in carbon (I'll very carefully glass bead blast those Monday) but all in all the engine was in much better shape than I thought it would be. Even the clutch looked good after 60,000 miles but the flywheel needs to be resurfaced since it shows some wear.
The valve and cam covers, get blasted and painted in silver (VHT paint) along with the fan and housing. I know I'll get lots of powder coat comments but to lazy. The cat BP also gets some VHT paint. The original muffler will also get blasted but I'm thinking of replacing it with a Flowmaster model named the Hushmaster (weighs less than 10 lbs versus 30 for stock) unless I hear some don't do it comments.
Any other suggestions would be very welcome. I'm sure one comment will be, "shoulda put in a 3.6". Thought about it but just can't swing the extra few thousand.
1987 911 Guards Red Targa, nearing 200,000 miles, lowered, 7's & 8's, 964 grind cams from John Dougherty, A.P.E. Mass Flow Sensor with chip to match, cat bypass, strut brace, dual out muffler. Will consider newer model in 8 years when I turn 75 and then maybe not.
2012 BMW 528i (wife's)
2007 Toyota FJ (rain and off road days)
Old 07-23-2005, 01:36 PM
Wer bremst verliert
JohnJL's Avatar
Don't forget another active member and helpful provider, drcamgrinder (http://www.drcamshafts.com/)
2007 911 Turbo - Not a toy
1985 911 Cab - Wife's toy
1982 911 3.2 Indiash Rot Track Supercharged track toy
1978 911 3.0 Lichtbau toy "Gretchen"
1971 911 Targa S backroad toy
Old 07-23-2005, 04:27 PM
Porsche Doc's Avatar
John dose great work.
Thanks!
Don Ramsay E Mail: aircooledclassicsporsche@gmail.com
The father of 964 Backdating!
www.aircooledclassics.co
www.facebook.com/AirCooledClassicsPorsche/ www.instagram.com/aircooledclassicsporsche/
Old 07-23-2005, 04:53 PM
Thanks guys. I saw his posts but didn't see he did cams. I'll call him Monday.
Old 07-23-2005, 04:57 PM
JBO JBO is offline
I would recommend Camgrinder (John Dougherty). He reground my SC cams to 964 profile. Did a good job and turnaround time was excellent.
Old 07-23-2005, 06:20 PM
MBruns for President
JeremyD's Avatar
I'll 2nd John - and I have cams on the way from him...
Old 07-23-2005, 07:34 PM
Rick Lee's Avatar
Another rec. for John. He made my SC cams into 964 cams - like magic.
2022 BMW 530i
2021 MB GLA250
2020 BMW R1250GS
Old 07-23-2005, 08:51 PM
Guys, I sent an email to John to get his input on the cams and also on the performance springs to increase RPM redline. If I should go for a higher RPM redline I'm guessing I also need to use different connecting rod bolts when I have the engine put back together. Any thoughts would be appreciated. Thanks
Old 07-24-2005, 05:34 PM
Jeff Alton's Avatar
John has ground a few sets of cams and rockers for me, all have been excellent.
Jeff
www.turn3autosport.com
Old 07-24-2005, 07:13 PM
Guys thank for the recommendations on using John. I talked to him this morning and shipped the cams to him this afternoon. Now I am a happy camper. The thought of spending all this time and money on a rebuild and not getting any new HP didn't make me happy. Now I am a happy camper.
I spent the afternoon bead blasting the fan, shroud, alum cam, and valve covers. Painted them silver tonight along with the cat BP. Also bead blasted all the carbon off the piston tops after taping the sides to protect them and keep the grit out. All the exhaust system parts get cleaned and polished or painted over the next few days. Should be back together and on the road late next week.
Last item to sort out is a new muffler. I'm leaning toeards have a shop take a Flowmaster on in on out muffler called the Hushmaster II. Weighs about ten pounds and costs $100.
Old 07-25-2005, 08:53 PM
camgrinder's Avatar
This thread makes me a happy camper!
Thanks guys!
John Dougherty
Dougherty Racing Cams
Old 07-26-2005, 10:25 AM
