sticky tappet?
Car is 996. What will happen if the tappet gets sticky? Will it affect the A/F ratio and cause the vehicle to backfire.
Also, aren't those hydraulic tappets suppose to be maintanence free? Do you know how they can worn out or get stuck? Thanks in advance.
I assume that 996 will behave similarly to 993. On 993 they do go bad and will need to be replaced, it's a simple, fairly cheap procedure. When they go bad the make a clattering noise and performance is affected to a relatively small degree. But OBD2 is very sensitive to this and it is not surprising that a code would be thrown.
The story I've heard is that it is a very expensive procedure coz they have to take out the engine and the camshaft in order to get to the tappets.
I don't think the tappets are making a lot of noise at this stage (am I suppose to hear a ticking noise if the tappets are not working right?), but I was told that it is not functioning properly and thus affecting the A/F mixture causing the misfiring or backfiring. Last edited by superfans; 07-26-2005 at 03:19 AM.. |
I only know 993, when they fail they make a loud metallic tapping, like a miisadjusted manual valve(that's essentilly what it is!)
I can only assume that 996 will make a similar noise. I can well believe that it is a far more difficult problem to correct.
Another stupid question, hope you don't mind. Why would a sticky hydraulic tappet or tappets will cause a misfire or backfire upon acceleration?
