daniell911's Avatar
Decklid Shock w/Carrera Tail
I just installed a Carrera Tail and my Decklid won't stay open as it is heavier now. Any recommendations?
I have one shock only.
is this Heavy duty will solve the situation?
Heavy-Duty Rear Engine Lid Shock, 911 (1974-89), each
Selling on Pelican here
It seems there's no attachment on the chassis for a 2nd shock
Tx for your help!
Old 07-27-2005, 07:31 PM
A trip to the garage shows the Passenger side shock mounted to a bracket attached to the hinge. The Drivers side is done in the same manner. A U bracket on the firewall is where the shock is attached at the rear.
As you can see I converted over to a locking shock (Driver's side) that is actuated by a sprung pin mechanism. I don't believe this product is available any longer as it was handmade years ago. Do you have the same bracket setup as my '85?
Passenger side:
Driver side:
Warren & Ron, may you rest in Peace.
Old 07-27-2005, 08:53 PM
x911x's Avatar
I have dual
since our host dont cary dual shock kit at the moment, I got mine from PP.
http://www.***************/ProductPage.aspx?pid=110045&name=Dual+Rear+Shock+Kit&type=20
thanks,
Dave
1979 SC Turbo Body, Indian Red
2000 E320 / CARLSSON
1962 Austin Mini Cooper 997
2004 Lincoln Aviator
Old 07-27-2005, 09:02 PM
Carl Bauer's Avatar
One new shock holds my factory carrera 3.0 tail just fine. You don't need two unless it a heavy intercooled turbo tail.
Carl Bauer - 1979 RoW 911SC - Orange Bar Products
Old 07-27-2005, 09:04 PM
PorscheGuy79's Avatar
Or you can PM me, I just took off my turbo tail off and have shock that works great that I dont need.
Matthew
“Sometimes the questions are complicated and the answers are simple.”
Old 07-27-2005, 09:07 PM
Detached Member
Hugh R's Avatar
I read on PP once that the spring on the latch, or something is different for cars with tails so that it will unlatch. I don't know if you have an unlatching problem or just a staying open problem. A neighbor has an after market tail and he has to pull the release lever, and have someone lift the deck lid to open it.
Hugh
Old 07-27-2005, 09:20 PM
x911x's Avatar
"A neighbor has an after market tail and he has to pull the release lever, and have someone lift the deck lid to open it."
I think this will be solved by adjusting the deck lid stops. It worked on mine, actually I changed to new ones.
thanks,
Dave
Old 07-27-2005, 09:30 PM
daniell911's Avatar
Exactly the same. My sons need to pull the release lever and I need to lift the decklid and maintain it open.
I have one shock installed which is not an heavy duty
Old 07-28-2005, 04:31 AM
Southern Class & Sass
Dixie's Avatar
Non-turbo passenger side decklid hinges do not have the tab hanging down to hook a strut to.
Dixie
Bradenton, FL
2013 Camaro ZL1
Old 07-28-2005, 04:43 AM
daniell911's Avatar
Capt. Carrera
Yes I noticed this is why I have a dillema what to do.
If I replace my existant shock with an Heavy Duty shock selling here on Pelican will solve the problem?
Retaining with a piece of wood doesn't look too sporty!
Old 07-28-2005, 04:47 AM
Bill Verburg's Avatar
You can weld a bracket to the other side of the chassis and use the same saet up as on the drivers side. The dual shocks on one side let the lid warp.
There is a heavier duty spring on the latch for cars w/ spoiler. I posted the part # once.
Bill Verburg
Old 07-28-2005, 06:03 AM
The Porsche part # for the pneumatic spring mount bracket Bill is refering to is 911 501 729 01. It runs about $20.00 from the dealer. You will have to modify your existing right side lid hinge or obtain a right side hinge from a Turbo or Carrera that was equipped with a shock bracket on the hinge. There is a raised area where the mount bracket attaches to the body so it is not difficult to locate the spot to attach the mount bracket.
Old 07-28-2005, 09:33 AM
The HD spring is part of 930.512.052.00 lock upper part used on M473 and M491 packages.
930.512.039.00 is the right hand side fastening plate which needs to be welded to the chassis to use a right hand side strut. It was std. on M473 and M491 packages
Bill Verburg
Old 07-28-2005, 12:58 PM
Correction
911.512.039.00 is the weld on bracket on the hinge
911.501.729.01 is the weld on body bracket
Bill Verburg
Old 07-28-2005, 04:36 PM
As mentioned my Carrera with factory tail had the mounting plate. When I went over to the turbo tail the standard struts were marginal.
If you'd like dimentions or better pics let me know.
Bill: is the M473 package the Carrera tail option?
Old 07-28-2005, 08:12 PM
this is a great thread for me. I've paid for an elec tail that's arriving in a couple of mo. Plenty of great info on this one.
thx all
Ronin LB
'77 911s 2.7
PMO E 8.5
SSI Monty
MSD JPI
w x6
Old 07-28-2005, 10:19 PM
As you asked for...
It held my Turbo tail up very well. Let me know.
Matthew
Old 07-28-2005, 10:39 PM
