New kid in town
71T Targa's Avatar
Too rich or too lean?
If/when I stomp on the gas, my car dies for a second and then takes off. Some times I need to feather the gas to get rolling. Ie. Give it a little, let up, give it a little more. Is this the result of a rich or lean condition?
’71 2.2 T with Webers.
I wish I still had 9111113443...
Old 08-04-2005, 01:40 PM
jluetjen's Avatar
How about the acceleration pumps?
John
'69 911E
"It's a poor craftsman who blames their tools" -- Unknown
"Any suspension -- no matter how poorly designed -- can be made to work reasonably well if you just stop it from moving." -- Colin Chapman
Old 08-04-2005, 02:17 PM
Unregistered
sammyg2's Avatar
Could be either, more information is needed but I'd say that too lean is more likely.
Old 08-04-2005, 03:51 PM
jluetjen's Avatar
If it's too lean, you'll find that the engine momentarily "picks-up" when you close the throttles. This is called "lean surge".
John
'69 911E
Old 08-04-2005, 05:20 PM
project 911's Avatar
Joel,
You might check your timing. If I set mine to the specs given in my manual, it falls flat on its face when you punch the gas. I just time mine by ear until the throttle response is crisp.
Steve B.
1971 T 2.2 w/Zeniths
Gruppe B member 171
Mid 9 Web Site Guy
Old 08-04-2005, 05:38 PM
jluetjen's Avatar
project 911; I suspect that your car's dizzy may not be advancing correctly. The factory settings should work great if everything is working correctly. The factory new what they were doing when they came up with those settings. Have you confirmed that your car's distributor is advancing according to spec?
John
'69 911E
Old 08-05-2005, 04:42 AM
John,
I had a lot of trouble with two of the original Marelli dizzys, then upgraded to a Bosch, but they all did the same thing as far as timing and throttle response. I imagine the newer Bosch may have a different curve as I think it was for an S model, but I have yet to check it. The car runs great, and 6000 rpm timing still falls in the 30-35 degree zone.
Steve B.
Gruppe B member 171
Mid 9 Web Site Guy
Old 08-05-2005, 04:50 AM
Steve,
I think John is correct. After I replaced my dizzy, it took some fiddling to get the advance curve correct again. It's good that you check the total timing, but if you do a search here, you can find the complete curve from idle on up. If you match that at idle, 1000 rpm, 2000 rpm, on up, I think you'll find the car runs great.
phred68 - Check your total timing at 6000 rpm like Steve did.
Good luck - Rex
1975 911s
1997 Saab 900s
Old 08-05-2005, 05:00 AM
New kid in town
71T Targa's Avatar
Thanks all, sounds like it might be lean, as I do get what John describes as "lean surge". When I come to a stop, the RPM's will pick up for a bit, and then settle in. The acceleration pumps measured correct when I rebuilt the carbs, and the timing is on at 6K. (Well I don't know if it's 6k, but once the advance stops)
Old 08-05-2005, 08:29 AM
