Question 911 69T 2.0 v. 2.2
1st post. were both the 2.0 and 2.2 put in 69T? it would appear that the stroke is the same for both. does this allow me to go from 2.0 to 2.2 with heads/pistons/cylinders upgrade. seems like an option.?
note: i put another post under classifieds by mistake with all #s for above, just learning.
Old 07-31-2005, 10:15 AM
araine901's Avatar
Yes you can. I did it to mine. If you keep the 2.0 heads you will need to get them machined to take the CE type head gasket. But if you get the 2.2 T pistons (E or S will have piston to valve issues if you have a T cam) and 2.2 heads it will "slip in" with not machine work requred for the case etc.
'66 911 (sold to Magnus Walker)
'63 Myers Manx
'67 Cal Bug
'02 GTI 1.8T
Old 07-31-2005, 10:54 AM
