Voltage Regulator Parts Question
I need some help. About a mile from home last night the alternator light came on, I pulled over and shut off the engine in case it was the belt. Belt was on and tensioned properly. WHen I got home, voltage reading at the batery with the car idling, with no load was 15.V volts.
My guess is it's the external voltage regulator. The car is a 1980 Euro SC, it has a S.E.V. Marchal 14V external regulator.
The photo of the Pelican regulator (C-608-901-00) looks a little different. I can't tell if it has the same eletrical plug connection as mine?
Here's what mine looks like.
Here's the Pelican regulator
Thanks!
John Adams
1980 ROW 911SC
Old 07-31-2005, 09:16 AM
Pelican part pic.
John Adams
1980 ROW 911SC
Old 07-31-2005, 09:21 AM
Early_S_Man's Avatar
Porsche Crest
John,
I'm not sure what that is a pic of ...
The line above it is the correct regulator for a 980 Watt/70 Amp SEV alternator:
Voltage Regulator, external (for Motorola 70 amp alternator) 911 (1974) [Photo] C-603-901-00 $63.75
Warren Hall, Jr.
1973 911S Targa ... 'Annie'
Old 07-31-2005, 09:39 AM
Thanks Warren.
The alternaltor I have is a Marchal, and the car is a 1980 SC. I found a picture of the bottom of the voltage regulator (911.603.206.13 which cross references with the pelican part C-603-206-13). Here's a pic of my alternator and bottom side of voltage regulator which also has the three spade connections. I'm prety sure the C-603-206-13 part number is the one I need.
John Adams
1980 ROW 911SC
Old 07-31-2005, 10:49 AM
