Replacing threshhold strip
I am thinking about replacing the rubber threshhold strip on my 89 Speedster (I'm running out of things to replace) and was wondering if it is glued in? Thanks!
Funnyguy |
Diss Member
The replacement will have a couple strips of double sided sticky pre-applied. Just get the old one out, clean up the sill and put the new one in.
I like to pull the strips off of the adhesive a couple inches and get the rubber lined up. Then gradually pull the rest of the backing off as you work your way down to make sure it is aligned perfectly.
- "Speed kills! How fast do you want to go?" - anon. - "If More is better then Too Much is just right!!!" - Mad Mac Durgeloh -- Wayne - 87 Carrera coupe -> The pooch. |
