-   -   Needed Weber part (http://forums.pelicanparts.com/porsche-911-technical-forum/234675-needed-weber-part.html)
GotaT 08-05-2005 06:44 PM
Needed Weber part
I have a 71 911t and need ONE more weber carb part. This may be difficult to explain but I will try.
Where the 2 fuel lines enter into the carb there are 2 16mm copper/brass bolts that are located on the top of the carb, one near each fuel inlet. I need one of these bolts. Can any of you help?? Or know where I can find this part, minus the pmo.
Mitch
PS... If you sell Weber parts give me a call
337.781.4433
mas2868@yahoo.com
campbellcj 08-05-2005 08:25 PM
If you don't want to order from PMO (I'm not sure why, but OK) then try Pierce Manifolds. They are another major Weber parts source.
http://www.piercemanifolds.com/products.htm
I have not done biz with them personally but have not heard any bad reports...YMMV
GotaT 08-08-2005 08:07 AM
Couldnt get the link to work... going to repost in the Classified section.. Thanks.
jpnovak 08-08-2005 08:26 AM
Those are just covers for the float level valves. They should be relatively easy to find. Try Pierce as suggested above. Do a Google search for them if the link doesn't work (link works fine for me). They are easy to find on the web.
GotaT 08-08-2005 03:37 PM
Really Need Help....
Ok, ive found the part #. Its called a "plug" and there are 2 required per 3 bbl carb.
Part # 61002.005
On the weber diagram i found it was part # 7
http://www.racetep.com/weber/40IDA_46IDA.pdf
If you have this part please let me know how much you would like for it. Mine was stripped before I got the car and Leaks fuel through it all the time :/
Mitch
mas2868@yahoo
TimT 08-08-2005 04:10 PM
You could get a 1/4" brass pipe plug, and tap the stripped hole for it..since you mention the drain hole is already stripped, all you have to do is take a trip to a good local hadware store, and buy a plug and tap..
GotaT 08-08-2005 04:51 PM
Good idea.. the only thing that is stripped is the brass plug and not the carb. However.. I may be able to get that plug and re tap the threads on it to match the weber carb. hmm.. I think im going to the hardware store.
Fishcop 08-08-2005 05:12 PM
There is a later 17mm version that you should get as oppossed to the 14mm version which does strip more easily.
CBRacerX 08-08-2005 05:38 PM
I have lots and lots of Weber parts in the garage, I'll take a look for you
Chris
GotaT 08-09-2005 05:38 AM
Thanks chris.. Ill be looking to hear from you! (crossing fingers)
Mitch
CBRacerX 08-09-2005 03:19 PM
I don't have one...
I have two - I think this is the part you need, yes?
Chris
http://forums.pelicanparts.com/uploa...1123625965.jpg
GotaT 08-09-2005 03:28 PM
Sweet.. those look like the ones! I'll take them.. how much for them shipped to 70503. please check to see if those are 16mm heads and are they about 1 inch overall height?
CBRacerX 08-09-2005 08:28 PM
I sent you a message at mas2868@yahoo.com
Butzijnr 08-03-2009 12:45 AM
Missing Weber part 61002.005
I wondered after this thread if anyone else was aware of where this part (Weber part 61002.005) could be sourced because I have exactly same problem in that the previous owner seems to have rounded off the brass plug or indeed as the originator of this thread managed to do find anyone with a spare.....
many thanks
Luke
SCrescue 08-03-2009 05:38 AM
Luke,
Try grinding it down to a smaller hex size or square it off. It won't be visible if you install any kind of air cleaner assembly.
Mike...:cool:
berettafan 08-03-2009 06:29 AM
Luke just call/fax PMO. It's a cheap part and frankly anyone who has webers would benefit from being familiar with Richard (PMO) and a few others (such as Pierce).
