GotaT's Avatar
Send a message via AIM to GotaT Send a message via Yahoo to GotaT
Needed Weber part
I have a 71 911t and need ONE more weber carb part. This may be difficult to explain but I will try.
Where the 2 fuel lines enter into the carb there are 2 16mm copper/brass bolts that are located on the top of the carb, one near each fuel inlet. I need one of these bolts. Can any of you help?? Or know where I can find this part, minus the pmo.
Mitch
PS... If you sell Weber parts give me a call
337.781.4433
mas2868@yahoo.com
Old 08-05-2005, 06:44 PM
Stay away from my Member
campbellcj's Avatar
If you don't want to order from PMO (I'm not sure why, but OK) then try Pierce Manifolds. They are another major Weber parts source.
http://www.piercemanifolds.com/products.htm
I have not done biz with them personally but have not heard any bad reports...YMMV
Chris C.
1973 914 "R" (914-6) | track toy
2009 911 Turbo 6-speed (997.1TT) | street weapon
2021 Tesla Model 3 Performance | daily driver
2001 F150 Supercrew 4x4 | hauler
Old 08-05-2005, 08:25 PM
GotaT's Avatar
Couldnt get the link to work... going to repost in the Classified section.. Thanks.
Old 08-08-2005, 08:07 AM
I would rather be driving
jpnovak's Avatar
Those are just covers for the float level valves. They should be relatively easy to find. Try Pierce as suggested above. Do a Google search for them if the link doesn't work (link works fine for me). They are easy to find on the web.
Old 08-08-2005, 08:26 AM
GotaT's Avatar
Really Need Help....
Ok, ive found the part #. Its called a "plug" and there are 2 required per 3 bbl carb.
Part # 61002.005
On the weber diagram i found it was part # 7
http://www.racetep.com/weber/40IDA_46IDA.pdf
If you have this part please let me know how much you would like for it. Mine was stripped before I got the car and Leaks fuel through it all the time :/
Mitch
mas2868@yahoo
Old 08-08-2005, 03:37 PM
Navin Johnson
TimT's Avatar
You could get a 1/4" brass pipe plug, and tap the stripped hole for it..since you mention the drain hole is already stripped, all you have to do is take a trip to a good local hadware store, and buy a plug and tap..
'69 911 GT-5
'75 914 GT-3
and others
Old 08-08-2005, 04:10 PM
GotaT's Avatar
Good idea.. the only thing that is stripped is the brass plug and not the carb. However.. I may be able to get that plug and re tap the threads on it to match the weber carb. hmm.. I think im going to the hardware store.
Old 08-08-2005, 04:51 PM
Bird. It's the word...
Fishcop's Avatar
There is a later 17mm version that you should get as oppossed to the 14mm version which does strip more easily.
John Forcier
Current: 68L 2.0 Hotrod - build underway
Old 08-08-2005, 05:12 PM
CBRacerX's Avatar
I have lots and lots of Weber parts in the garage, I'll take a look for you
Chris
Chris
https://dergarage.com
‘11 987.2 CS, '01 986S, '11 958S, '24 R1T, '87 Defender V8
Old 08-08-2005, 05:38 PM
GotaT's Avatar
Thanks chris.. Ill be looking to hear from you! (crossing fingers)
Mitch
Old 08-09-2005, 05:38 AM
CBRacerX's Avatar
I don't have one...
I have two - I think this is the part you need, yes?
Chris
Old 08-09-2005, 03:19 PM
GotaT's Avatar
Sweet.. those look like the ones! I'll take them.. how much for them shipped to 70503. please check to see if those are 16mm heads and are they about 1 inch overall height?
Old 08-09-2005, 03:28 PM
CBRacerX's Avatar
I sent you a message at mas2868@yahoo.com
Chris
Old 08-09-2005, 08:28 PM
Missing Weber part 61002.005
I wondered after this thread if anyone else was aware of where this part (Weber part 61002.005) could be sourced because I have exactly same problem in that the previous owner seems to have rounded off the brass plug or indeed as the originator of this thread managed to do find anyone with a spare.....
many thanks
Luke
Old 08-03-2009, 12:45 AM
Luke,
Try grinding it down to a smaller hex size or square it off. It won't be visible if you install any kind of air cleaner assembly.
Mike...
'84 Carrera Targa (3.0 with SSIs, Webers, DC-19 Cams, MSD) - Sold
Old 08-03-2009, 05:38 AM
(the shotguns)
berettafan's Avatar
Luke just call/fax PMO. It's a cheap part and frankly anyone who has webers would benefit from being familiar with Richard (PMO) and a few others (such as Pierce).
Old 08-03-2009, 06:29 AM
