electrical problems
I have a porsche 930 turbo that i rebuilt the motor for a friend. i rebuilt it and now neither of the fuel pumps work. i have traced it back to the air flow meter relay. if i ground the terminal on the relay for the fuel pump turns on but during starting it turns off. any ideas???
Old 08-05-2005, 06:52 PM
ttt
Old 08-06-2005, 09:17 AM
Check that you haven't switched the connectors for the airflow switch and the cold start valve (CSV).
CIS works only then starter is on
Old 08-06-2005, 08:52 PM
i have checked those connectors and they are not switched. also there is a tube on the wastegate valve that i have no idea where it goes. Any ideas!!! the car has a body kity on it so the intercooler is in the drivers fender so the guy that did it messed up the car pretty bad
Old 08-07-2005, 09:00 AM
