First Oil Change (what not to do)
Well the 5,000 mile oil change came today and here's a few pointers for those newer to Porsche than I (not many).
Be sure and turn the drain plugs in the correct direction as they are much easier to remove. The Oil change pan sold by pelican works really good (unless you let the drain plug fall into the pan at which time it does its job and "Plugs" the hole the oil was draining into). Of course in the "Panic" mode I didn't think to move the plug out of the pan. This caused about a quart to overflow onto the garage floor to the sounds of "Honey bring me a towel!!". Well the next plug stayed in my hand and managed to not plug the hole. Also found out my Wal Mart floor Jack will not raise the tires off of the ground with the recently acquired Jack Pad from Pelican. I think it has a limit of 13" which is not Jack . . . for a Porsche. All in all it was a fun time and a learning experience. Test drive went well and after putting a total of 10.5 qts in it it runs great. Temp reads just barely above the window and pressure was 4 bar at 5,000 rpm. Now next 5,000 DIY service will include a valve job and I will be counting on all of you for tips. Thanks to all!! |
Automotive Monomaniac
All "first" oil changes are a learning experience, no matter what the car.
My best "learning experience" was dropping a slippery oil filter into the catch basin of hot oil - while my head was under there! I emerged very "freckled" with hot oil, and feeling a bit stupid. However, never made that mistake again.
2018 - Porsche 911 Carrera 7MT / 2018 - Porsche Macan 7DCT / 1993 - Cadillac Allante / 2023 - RAM TRX (on order) |
5,000 miles is too long.
1985.5 944 GTS |
Factory spec for oil changes on my 74 are 10,000 miles (or every 6-months). Depending of course on how hard you drive you car and for how long, I see no problem with going 5-8k miles. 12 quarts takes a long time to degrade compared to 5 quarts in a normal wet-sump. I believe the interval increased later on on oil capacity continued to increase and oil cooling improved, a la 964/993.
lift - put car on stands - lower lift & put big wood beam there - lift again & set stands
then push every which way - before putting your life under the car helper with cell phone on is handy - if not, then keep cell phone on & w/in reach at all times if solo I know very few people who can bench press the rear end of a Porsche
"A man with his priorities so far out of whack doesn't deserve such a fine automobile." - Ferris Bueller's Day Off |
first time I did it I found out how fast the oil comes out and had to act quick - my oil pan doesn't hold enough and,,, you can guess - we need a thread on best approach to clean up oil off a garage floor,
1978 911SC 3.0 "Guards" |
RETIRED
Have a pan that is big enuf....12 quart capacity or more....remember to put plugs back in.....put 8 quarts in and start up....get warm and thermostat open, check dipstick on LEVEL ground, fill to bottom line. Go fer a drive.....check when ya stop...have a beer.
1983/3.6, backdate to long hood 2012 ML350 3.0 Turbo Diesel Last edited by Joe Bob; 08-07-2005 at 02:32 PM.. |
Thank you, Bagpiper47! I think I am newer than you are, with my first oil change fast approaching, so your "lessons learned" story was very helpful.
Michael 1987 3.2 Carmine Red Carrera 1995 Midnight Blue 993 C4 1957 Silver Speedster Outlaw (replica) |
First Oile Change
In 1978 I purchased a 1973 911T and on the following Saturday's I decided to change the oil. I bought a new filter and six quarts of oil. I had zero experience with 911s, but I soon learned that the pan that I had used for other cars was to small!!!!!!!!!
My garage and driveway looked like a oil tanker ran aground. You can't fit 10 quarts into a 6 quart pan.
1987 911 Coupe Triumph Trident Track Master History is the lie we all agree to.......... |
GOT TURBO..
Re: First Oile Change
Come on, i know you got a pix or two.. I did almost the same thing, but both pan did the over flow HAHAHAH boy, was that dumb.. |
Ahhhh, memories! I think we've all had a bad experience with those shallow drain pans that have a small hole in them...then learning just how fast the oil flows from a 911...
"Now, to put a water-cooled engine in the rear and to have a radiator in the front, that's not very intelligent." -Ferry Porsche (PANO, Oct. '73) (I, Paul D. have loved this quote since 1973. It will remain as long as I post here.) |
Oil Change
It flows much faster when it is hot!!!!!!!
If there is a dumb mistake to be made; I have made it. The punch-line to my mistake is that I spent the rest of the day and the following Sunday cleaning up the mess. We had just moved into a new home and the driveway dropped about 24 inches in 20 feet. The hot dirty oil ran down the drive; the new drive.
on the subject of oil changes.....
Can I remove the oil filter without first draining the oil? Other than residual oil in the filter, will tons of oil come pouring out? It's a long story why I want to do this, but basically through a miscommuncation, the oil got changed, but not the filter..... Thanks, apologies if I'm hijacking.
Doug Andrews 1982 911SC Targa 2008 Silverado Duramax 3/4 ton 2004 Armada 1999 Honda XR400 |
dandrews64,
Yes you can remove the filter (engine off of course) and only loose the amount of oil that resides in the filter. Put your pan under the car as there will ineveitbly be a few drips. Don
72T Coupe - SOLD :-( |
doug, just jam a rag under the filter first. no issues.
not to brag guys,...but i didnt destroy my driveway, until my fourth oil change. (first for this SC). guess i am just smart like that.... only time i was glad we owned a cat. cat litter is great for clean up. hint; use NEW cat litter.
poof! gone |
FYI, Plastic kitty litter box works well for large oil pan, also very cheap.
-Matt 1985 Targa |
Unregistered
IMO changing the oil every 5000 miles is just fine, you could go further if you wanted to. Anything more frequently would be wasting oil and money unless it is a race engine or subject to extreme temperatures/conditions.
This subject has been beat to death here lately. |
It takes a lot longer than 5,000 miles to contaminate 14 qts of oil. That said, don't go longer than 12 months. I change mine ever 12 months, which works out to be 2,500-3,000 miles.
Gone but not forgotten - 1980 Porsche 911SC w/ -22mm/28mm Torsion Bars | Custom Valved Bilsteins | 22mm/21mm Carrera Sway Bars | Elephant Poly/Bronze Bushings | Carrera Brakes | AJ-USA Brake Cooling | Carrera Oil Cooler w/ Fan | Elephant Strut Brace | Oh, and no ABS or PSM or A/C |
