I'm nearing completion on the build of a 3.5 twin plug from a 3.0 liter (100 P/Cs, 3.2 crank) and I'm not sure what to do for exhaust. I have a set of SSIs on my current 2.7 but have been told they will not be enough for a 3.5 and that 1 5/8 headers/HEs is the way to go. I've searched the forums on headers, GHL heat exchangers, B&B, etc. I would like to be able to use a Dansk dual in, dual out muffler. So what are my best options with and without heat?
Still Doin Time
MO is a cheap option is 964 stock headers / exhaust. To me the GHL's are a copy of the 964.
OR open up your wallet for a set of B&B's
'15 Dodge - 'Dango R/T Hauls groceries and Kinda Hauls *ss '07 Jeep SRT-8 - Hauls groceries and Hauls *ss Sold '85 Guards Red Targa - Almost finished after 17 years '95 Road King w/117ci - No time to ride, see above '77 Sportster Pro-Street Drag Bike w/93ci - Sold |
Me like track days
I'd do a B&B w/heat with Fabspeed partial stainless (Flowmaster) muffler
- Craig 3.4L, SC heads, 964 cams, B&B headers, K27 HF ZC turbo, Ruf IC. WUR & RPM switch, IA fuel head, Zork, G50/50 5 speed. 438 RWHP / 413 RWTQ - "930 is the wild slut you sleep with who tries to kill you every time you "get it on" - Quote by Gabe Movie: 930 on the dyno |
964 setup is an option I had not considered. Is it a straight bolt-up?
Craig- do the B&Bs have spacing that is different than stock? In other words would a Dansk dual in, dual out bolt up to them? Keep the ideas comin... |
Still Doin Time
The 964 headers bolt up but I'm not sure of who or how many companies make aftermarket exhaust to go from the headpipes.
Me like track days
The B&Bs won't bolt up to the Dansk.
Too bad, the Dansk is a great muffler - one with more hair and about 4-5 hp = the FLowmaster. But a LOT louder, I loved mine.
Have you considered 993 HEs (rotate pass side flanges) and a Triad or MacNeil muffler?Lot,s of discussion on 3.6 exhaust should be relevant to a 3.5.
1980 911 SC 3.6 coupe sold 1995 993 coupe 1966 Mustang Shelby clone 1964 Corvair Spyder Turbo gone 2012 Boss 302 |
Do a search for carrera3.5L here. You'll see what Ralph did on his 3.5L motor last year.
Ed Hughes 2015 981 Cayman GTS 6 speed,Racing Yellow Past:1984 911 Targa (Ruby), 1995 993C2 (Sapphire), 1991 928S4 |
The best available off the shelf solution is the B&B, but as has been mentioned they use a non std. spacing between the collector ctrs. Most of us have used a Flowmaster X-flow muffler as a solution, it is loud but not unusably so.
Another issue is heat, even a track only car will want to be able to demist the windshield occasionally. If you insist on using the Dansk, headers w/o heat are the only solution, in the 1 5/8" or bigger range, that I know of. Unless you modify the exhaust inlets. 993 headers would work but again the Dansk won't bolt up w/o modification to the muffler and headers. If you have gone to the trouble of using some cams w/ some overlap then the 964 solution is not a good one. It would be fine for smog cams but not more agressive performance cams.
I'm open to different mufflers. I've looked into Ralph's solution and the headers are certainly a good option, but no heat. Any opinions on the GHL heat exchangers? Do they use standard spacing? I am using 964 cams to remain smog compliant.
Here is a sound clip of the Flowmaster on my 3.8
Wow! That is a great sound. Very aggressive but still 911. Thanks for posting that Bill.
I've been trying to get one accelerating and on the road, but I need a better mic setup. It really is a treat for an enthusiasts ears.
Me like track days
Me like track days
Here's a pic of Joe Fabiani
Craigs B&B appear to be the Carrera version, note the round heat inlets. If you want to use the Carrera heat tube that is the version you want.
I had mine(1 3/4") made w/ 964 heat inlets(oval) for use w/ the 964 heat tube. You can also have them made w/ the smaller 1 5/8" tube. .Joes kit is nice if expensive. The tips make it worth while, if you don't care about tips just get a couple of 2.5" ss Us and a flowmaster muffler. To tone it down a bit w/o building excessive backpressure Car Chemistry inserts are reported to work nicely. Craigs also appears to be set up for US 993 dual O2 sensors
Me like track days
Correct on both counts
I have plenty of lead for my pencil... just not enough paper to write on.. 82SC with 95 993 engine 2004 Ford Powerstroke |
Doesn't want/need a 3.6L
Jon,
Have you gone soft on us SoCal guys since you moved up north? Need heat? Has Bert taken any pics of the motor for you along the way? When you come down, we'll hook up if you are interested and you can listen to my car and determine if the noise level is objectionable. I have a dansk dual-in dual out w/ 84mm tips at present but just bought a dual-in dual out Monty w/ 75mm tips. The inlet flange i.d. on the Monty is 5mm larger than the Dansk and MAY be better suited for larger diameter headers. Planning on dyno'ing both back-to-back next week if possible to confirm. Ralph |
