-   -   Dropping a motor in 5 easy steps (http://forums.pelicanparts.com/porsche-911-technical-forum/235136-dropping-motor-5-easy-steps.html)
Shaun @ Tru6 08-08-2005 07:23 PM
With 2nd gear gone for 2-3 weeks now, and serious withdrawal symptoms setting in from having to drive the Jeep, I decided it was time to get on the ball and at least get the motor out and get the trans prepped for rebuild. We just put this combo in a few months ago so everything came away freely, cleanly, I think I only swore once when oil got everywhere coming from the hardline. Anyway, my version of dropping a motor in 5 easy steps.
Step 1: Select a car. This one looked a bit ratty being cursed and regularly hit, but so much the easier with no rear valence. Mig comes out soon to put a new lens panel in.
http://forums.pelicanparts.com/uploa...1123553679.jpg
What we're working with: Time: 7:19 PM tonight
http://forums.pelicanparts.com/uploa...1123553728.jpg
Step 2: Disconnect everything.
http://forums.pelicanparts.com/uploa...1123553788.jpg
Step 3: I still love the 2 jack method, though I was without my favorite 2x2 board. :(
http://forums.pelicanparts.com/uploa...1123553855.jpg
Step 4: Lower it carefully down and away. Missed one thing on the way down: trans ground strap, otherwise smooth sailing. Time: 9:19 PM
http://forums.pelicanparts.com/uploa...1123553925.jpg
Step 5: Italian sub with cappicola, salami and ham and doused with Caesar dressing. MMMMMMM
http://forums.pelicanparts.com/uploa...1123554004.jpg
Tune in this weekend for the trans rebuild. that will be scary!!!
azasadny 08-08-2005 07:51 PM
Good work!!
Shuie 08-08-2005 08:28 PM
Step 6: Put on pallet
Step 7: Bring to Forward Air
Step 8: Send to Baton Rouge terminal
Nice work!
randywebb 08-08-2005 09:53 PM
Step 9. Pick up engine and get a nice Oyster Po-boy to go.
Shaun @ Tru6 08-09-2005 04:48 AM
God that sounds great!!!!
Sherman, if you want it, seriously, we can work out a deal. My goal for the car is to make it into a turbo-cab, no tail, when doing all the bodywork (a lot!). Was planning on this winter, but could see reprioritizing, focusing on the body, and when the time comes for a motor, I could consider a 3.6 or 3.3 turbo.
Doug&Julie 08-09-2005 05:15 AM
Step 4.7: Wash hands! :p
Mysterytrain 08-09-2005 07:58 AM
er, excuse me but no jack stands? Nothing like living on the edge.
Shaun @ Tru6 08-09-2005 08:10 AM
Only while working under the car during prep. When dropping the motor... no.
klaucke 08-09-2005 08:17 AM
I'd like to see what's going on when you tear into the 915 box, let me know if you need some help!
Shaun @ Tru6 08-09-2005 08:25 AM
Jonathan, I'll be at Chris Bennet's house in NH this Saturday at 10. You are welcome to stop on by.
Dottore 08-09-2005 08:54 AM
That looks like one rusty car.
Is that from the salt on the roads where you live - or do you live next to the sea? What gives?
Argeo 08-09-2005 09:04 AM
I think that rust is actually glue that use to hold the engine pad in place.
Shaun @ Tru6 08-09-2005 09:25 AM
David wins! this car is on a serious diet, and motor sound pad is sort an oxymoron, don't you think?
naparsei 08-09-2005 09:43 AM
Is there more info on the "two jack" method? I will doing the engine drop soon. I understand about the jack under the block, but what happens to get the car so high? It looks like the jack is almost in the middle of the car. I assume either you chock the front wheels or use jack stands?
I guess for Shuie its the "Tujague's" method?
Shaun @ Tru6 08-09-2005 10:54 AM
Here it is in reverse:
http://forums.pelicanparts.com/porsche-911-technical-forum/171943-project-73-911-r-rs-week-13-a.html
Front wheels are chocked.
One jack is at the very rear of the floorpan with a 2x8x24. With an appropriate jack, you can raise the car very high.
With the tires still on the rear, I jack up the floor so tires are 2 inches or so off the ground and then, in a very controlled way, grab the car and *try* to tip it over, that is, really see how well it's on the jack.
Hope this helps and good luck with your drop!
ChrisBennet 08-09-2005 11:10 AM
Hey Jon,
I've been putting on get togethers for a few years which I call Messin' with 911's. We get together and work on a motor, transmission or someone's car. You can watch, help, work on your own car or just drop by for lunch and abuse.
The sessions are pretty infrequent and it's usually only a couple of guys. Here's some pics from the last one:
http://forums.pelicanparts.com/showthread.php?s=&threadid=163271&perpage=20&highl ight=queen&pagenumber=2
I'm having a transmission rebuild session next Saturday. Shaun's transmission has some demons in it that need to be exorcised.
-Chris
9dreizig 08-09-2005 11:18 AM
Shaun and Chris,
I'll be interested in having you drive my 930 and make a diagnosis on my tranny..
What kind of beer are we drinking Sat ??
Todd
Shaun @ Tru6 08-09-2005 11:23 AM
Todd, what seeems to be the problem with it?
Chris is the master tranny man BTW. I'm just good at tearing things off cars.
getting them back on, that's a whole 'nother story.
klaucke 08-09-2005 11:25 AM
I've been fixing my boat pretty straight out lately, especially on weekends, but I might hopefully be able to play hooky for a bit to drive on up. My 915 needs a rebuild quite badly, so some experience is a plus.
9dreizig 08-09-2005 11:29 AM
2nd gear grinds when ANY kind of speedy shift is put on, I really have to let the rpms drop in order to get it not to make noise that sends the hair on my back on edge.. More like a gas, clutch,,, one thousand one, shift..
I knew this when I bought it, but it can be shifted without it but not a lot of fun..
