How does one remove rust from here?
I was wondering if anyone could shed some light on this. It's the area where the parcel shelf meets the left and right corners of the rear. I removed most of the sound deadening material but am wondering if anyone out there has done some work in this spot. I'm sure there's a quick fix. ;)
thanks for the replies... |
rust in the rear window/shelf
Sand blast the inside, being careful not to warp the surface metal.
Heat and remove the lead from the outside surfaces. Weld in a patch for the hole(s). Re-lead or fill/blend the low area's. Etch and prime inside and out. Or you could use POR15 on the inside surfaces with the etch and prime on the outside. Bob |
| All times are GMT -8. The time now is 07:22 PM. |
