I'm not here.
K. Roman's Avatar
How does one remove rust from here?
I was wondering if anyone could shed some light on this. It's the area where the parcel shelf meets the left and right corners of the rear. I removed most of the sound deadening material but am wondering if anyone out there has done some work in this spot. I'm sure there's a quick fix.
thanks for the replies...
"When do we say we can stop the Whole-Sale State-backed discrimination against straight white males? - island911 (This guy is insane, no?)
Old 08-09-2005, 07:51 PM
I'm not here.
K. Roman's Avatar
Old 08-09-2005, 07:55 PM
Fleming's Avatar
rust in the rear window/shelf
Sand blast the inside, being careful not to warp the surface metal.
Heat and remove the lead from the outside surfaces. Weld in a patch for the hole(s).
Re-lead or fill/blend the low area's.
Etch and prime inside and out. Or you could use POR15 on the inside surfaces with the etch and prime on the outside.
Bob
Old 08-10-2005, 11:11 AM
