WydRyd's Avatar
Upgrading heater fans?
Hi,
Is it possible to upgrade the side kick panel heater fans, by perhaps fitting a fan with a larger CFM rating?
Has anyone does this before? If so, what size/CFM fan did you use?
Just curious
Merv
'89 911 Turbo Cab
Protomotive MAP ECU, Twin Plugged Heads, GT2-EVO CAMs, 3.3L fully finned P&C's, ARP fasteners, C2T head gaskets, Titanium Retainers, Turbo spec valves, springs & guides, 964 splash valves, GT35R BB turbo, GSF Stainless Headers, Magnaflow Exhaust, Full bay Intercooler, TiAL 46mm w/gate, TiAL 50mm BOV, Apexi AVC-R EBC, SPEC Stage3+ Clutch kit, Crane CDI Ignition
Old 08-10-2005, 11:40 PM
I went down this road when I was looking for an option other then the factory kick panel blowers for my 78. What stopped me dead in my tracks was the heated air temperature. I don't recall the exact value [ but the number is in one of my past posts] but it was in the neighborhood of 225 degrees at the deforster vents! That temperture makes it very hard to find electric motors that like to work in such a harsh environment. I ended up using a pair of used factory blowers and I'm very happy with the results..heat and air flow.
Peace, Ron
www.ronorlando.net
78SC Targa 3.2 SS, 964 cams, CIS, SSI's,Dansk
Own a gun and you can rob a bank , own a bank and you can rob the world.
Old 08-11-2005, 06:04 AM
cali74's Avatar
I was considering adding something like this for defrost in my car
http://www.jcwhitney.com/autoparts/Product/tf-Browse/s-10101/Pr-p_Product.CATENTRY_ID:2002936/showCustom-0/p-2002936/N-111+10201+600002304/c-10101
Maybe it would help you having another blower in series?
74 911 with '95 3.6l
Old 08-11-2005, 02:34 PM
I bought something similar to that on Ebay for around $25 through www.racecityraceparts.com. Can't remember CFM, but it is 3" around at openings and made by Detmar. I have yet to install it though.
Scott Clevenger
1989 BMW 325ix 190K
1981 911SC 110K miles
http://www.pelicanparts.com/gallery/clevy70911T/
Old 08-11-2005, 03:43 PM
Air Medal or two
afterburn 549's Avatar
if you put holes in the front of the car you can force in a lot of air and get rid of it all (the electric crap)
D troop 3/5 Air Cav,( Bastard CAV) and 162 Assult Helicopter Co- (Vultures) South of Saigon, U Minh Forest, Delta, and all parts in between
Old 08-11-2005, 05:27 PM
WydRyd's Avatar
Thanks for the responses/suggestions.
I have poor airflow into the cabin because I've removed the engine compartment blower in order to fit a full length intercooler, therefore, my heating relies solely on the factory footwell blowers, which I think are on their way out. They don't flow enough CFM to effectively draw the heat from the Oil Cooler HEat Exchanger I have, below.
Merv
'89 911 Turbo Cab
Old 08-11-2005, 06:53 PM
cali74's Avatar
found that Detmar one...
http://www.prosystembrakes.com/catalogpg022.htm
Old 08-11-2005, 07:52 PM
WydRyd's Avatar
Cool! Thanks for the URL!
Merv
'89 911 Turbo Cab
Old 08-11-2005, 08:11 PM
Merv,
I'm using SSI's and just the footwell blowers and I have more heat then I know what to do with. It will melt your plastic ta-ta's! If you had automatic heating system then the blowers need the rear blower or a power resistor to trick the system that the blower is in place.
Peace, Ron
www.ronorlando.net
Old 08-12-2005, 07:20 AM
