Need quick answer: Will VW CV half moons work for an SC?
Hi Folks,
I'm replacing my CV boots today. My old ones had a thick flange on the end which did not 'wrap around' the joint itself; merely sat on top of it. I cannot seem to get these same boots anywhere. I ordered a set from our host, but they are the VW type where the flange is a thin, sheet metal affair that has a cylindrical section that fits down over the joint itself. From reading here, I understand that due to the softer metal of this type of boot, and also because of the bolt length difference this design would require, it's highly recommended to use the VW style steel half moons and Schnorr washers under the bolt caps. I'll be doing the work at a friend of mine's VW shop, and he's bound to have plenty of these around. My question is, will the VW half moons fit the bolt spacing on an SC's joints? Please let me know. Thanks, ianc
BMW 135i. Nice. Fast. But no 911... "I will tell you there is a big difference between driving money and driving blood, sweat and tears." - PorscheGuy79 |
Virginia Rocks!
I had a pro wrench tell me to use the shorter bolts and blue locktite. No moons, no washers.
Rosewood 1983 911 SC Targa | Black 1990 944 S2 | White 1980 BMW R65 | Past: Crystal 1986 944 na Guards Red is for the Unoriginal
I'm actually at the shop now and I've answered my own question: the VW moons are exactly the same, so I'll be using them. Thanks for the response!
ianc
Here's a few pics of the process:
Here are the (weird) old style boots with the thick flange: Outer flange with gasket glued in place: Axle assembled: Detail of joint: Installed: ianc
MBruns for President
man your tranny is dirty!
Current Whip: - 2003 996 Twin Turbo - 39K miles - Lapis Blue/Grey Past: 1974 IROC (3.6) , 1987 Cabriolet (3.4) , 1990 C2 Targa, 1989 S2 |
It wasn't 50K miles ago smart guy!
![]() ianc
Got a part # for those half-moons? I'd like to pick up some. I only have washers on mine.
2022 BMW 530i 2021 MB GLA250 2020 BMW R1250GS |
I don't have one Rick, sorry...
The shop my friend owns specializes in VW buses however, so they should be fairly easy to locate if you have any VW shops in your area. You can see their shape in the third shot down to the left. I used these and the thin serrated washers that come with the joints, and the length with the long bolts was just perfect, with around a mm or less sticking out the back of the flange. ianc
Looks great - except the tranny (and you know I'm pulling your leg, right?)
Thanks! I replaced all the joints with new Lobro's too. Not cheap...
![]() ianc
