-   -   Need a little engine room help (http://forums.pelicanparts.com/porsche-911-technical-forum/236042-need-little-engine-room-help.html)
K9Torro 08-14-2005 02:34 PM
Hi
Can anyone take a look at the pic below, and tell me what hose I am missing that connects where the red arrow is drawn to that large round opening coming off the fan shroud, and where it is supposed to go ?
Thanks in advance,
Todd SmileWavy http://forums.pelicanparts.com/uploa...1124055278.jpg
DonMo 08-14-2005 02:37 PM
Through the engine tin to the heater duct on the heat exchanger. It is your heat.
svandamme 08-14-2005 02:38 PM
hot air blower and tubing
K9Torro 08-14-2005 02:43 PM
Hi
Thanks for the help, my car does not have heat, the PO took put on a aftermarket exhaust and it uses the open tube design headers, any idea on what else I could use this for?
Todd SmileWavy
svandamme 08-14-2005 02:46 PM
just make sure it's plugged up or you loose cooling
the right side has a blocking plate , but the left side doesn't
unless it's plugged inside the socket , the fan will blow through that hole , instead off blowing over your heads and cyllinders
svandamme 08-14-2005 02:51 PM
PP sells block off plates
you have the right one , migt get the left one , not expensive
made out of plastic , see the one on my engine
all you need to do is unbolt the old hot air socket
drill a hole in the new plastic one
and bolt it in place
http://forums.pelicanparts.com/uploa...1124056178.jpg
