911 redline
when does the rev limiter kick-in on the 82 911 because I was half way in the red and nothing happened. No light, beep,or anything.?
82's rev limiter kicks in at when the first valve crashes into a piston.
Edward
993: retired Trackmeister, now daily driver heaven 911SC: resident Trackmeister-in-progress |
thats what I thought
There is also a blue light that comes on in your rear view mirror.
David |
Well, you didn't say whether it is a ROW or USA-spec car ... but, both had rev-limiters -- different types!
ROW -- rev-limiter rotor ... USA -- speed switch cuts off fuel pump ...
Warren Hall, Jr. 1973 911S Targa ... 'Annie' 1968 340S Barracuda ... 'Rolling Thunder' |
drag racing the short bus
The rev limiter really kicks in when your wallet's empty.
durn for'ner
Interesting, Warren !
Why are there different types of rev-limiters ? .... then there is the blue light coming on.... Fell off the chair!!
Markus Resident Fluffer Carrera '85 |
1982 Porsche 911SC Coupe - Factory Short Shift |7:31 R&P in AL case | Toyo RA1 Tires | Corbeau TRS seats | M&K 2 in 2 out muffler |
I like Orange
ROW - just check that dizzy rotor! I have seen a few cars fitted with a non-OE rotor that DID NOT have rev limiter...
I even saw someone 'modify' the rotor, supposedly for track use - so check your limiter! BTW, reving the motor up in gear is normally safe (ish...) but miss a gear shift and none of the old factory rev-limiters will save you.
“Rules are meant to be interpreted…” http://www.cafe9.co.za |
The fuel cut-off switch on my US 83 SC kicks in at just over 7K.
Jim Dowty 97 911 Coupe (Forest Green metalic, sunroof, leather) PCA RSR region Insurance chair and Board member Gruppe B #309 |
