P.S.
Dyno of MB 2.3 16v before and after it has been "liberated" from CIS flapper. CIS body has been kept the same but it has been "gutted" from flapper: ![]()
Thank you for your time, |
Goran, I've also got my CIS biturbo system working great with a pair of Andial 959 (grind) cams...which shouldn't work well at all with CIS . When prices/availability of CIS parts become an issue, I will upgrade to MoTech...until then
So...back on topic for now Marty
Porsche builds the 21st century 9146 so easy...even a Cayman can do it ! |
Goran, tell me more about the liberation of the flapper on the MBZ.
John Brasfield 91 C2 78 SC For sale 76 3.6 68 Datsun 2000 Mr. Magoo, 02 330ci |
Hello!
Car is owned by a gentleman I "know" from local swedish track-racing forum. He converted from CIS to to aftermarket injection system (MAP-sensor speed/density). So it's a basic EFI-conversion where he replaced CIS injectors with EFI-ones but opted to keep gutted K-Jet assembly in order to simplify plumbing and retain stockish looks (important for smog-check here in Sweden). So motor is EFI-converted mill that draws air trough hollow K-Jet. I just opted to use his dyno graph as a interesting example of possible gains attainable by replacing K-Jet with something flapper-less. I'll try to dig out his thread, there are more pictures of gutted CIS. Regards, Goran
95' Mercedes E300 Diesel (Azure+Sodalith Blue) 88' Porsche 911 Targa (FOR SALE) (Guards Red) |
Does anyone know if I can bypass the thermatic valve with the vacuum line and route it directly from the throttle body to the distributer?
2008 BMW 320i 2006 Mercedes ML320 2004 Mercedes ML270 cdi 1998 Porsche Boxter 1988 Porsche 930 Targa (sold) |
OK I am ready to put this engine back in. I found and fixed the following problems.
1. Air leaks under intake manifolds repaired (Thanks Maltese Falcon) Due to manifold not torqued down enough. 2. Leaking Vacuum advance line fixed and routed to bypass thermatic valve. 3. Rocker arms now torqued to 25ft/lb with rsr seals (instead of factory 13.2ft/lb) 4. Leaking turbo oil feed line repaired 5. Cam timing was 0.8/0.65 and now set correctly at 0.7/0.7 6. #6 exhaust valve gap was 0.4mm now 0.1mm I believe that the low power issues were a result of 1,2,5 and 6. Steve
Cigars and 911's -- Smile
As I a newbee, I am thrilled to read posts like these. Sometimes I have to re-read 2 or 3 times, but they are good learning material for me.
-Tom
[GruppeB # 978] 1978 911 SC ROW (Pure Euro, no DOT or EPA work done..) 1991 Toyota MR2 Turbo (3S-GTE 4Banger Rocket) 2001 Audi - A6 Quattro 4.2L-V8 (love the growl) 2014 Honda Odyssey for the soccer-team/accessories |
Good luck! I am sure you will let us know how it feels or show us the chart if you put it back on the dyno
Andy |
Its been a while since I started this thread, but I finally seem to have found the problem.
It was fouled fuel injectors. I took the fuel injectors in to a local shop to be tested and they flowed very unevenly, two of them hardly flowed at all. The spray patterns were all over the place at different pressures. I have now had that tank removed and cleaned, replaced the rear fuel pump, fuel accumulator, fuel filter and put in six new injectors. Apart from dirty fuel this vehicle had sat for some time. I think I found at least 80 horses. I am rather relieved.... I'll post a dyno chart when I get a chance to have it done.
Unregistered
Not only did you fine extra HP, you prolly saved your pistons. turbos don't like runnig lean under boost and that is exactly what a partially clogged injector will do to a cylinder.
Now go out and enjoy that monster
Author of "101 Projects"
CIS is limited because it uses relatitvely low-lift cams to avoid fuel reversion affects in the throttle body system. I suppose one *could* somehow make a CIS system that would work on independent throttle bodies, but it would be a lot of work. -Wayne
Wayne R. Dempsey, Founder, Pelican Parts Inc., and Author of: 101 Projects for Your BMW 3-Series • 101 Projects for Your Porsche 911 • How to Rebuild & Modify Porsche 911 Engines • 101 Projects for Your Porsche Boxster & Cayman • 101 Projects for Your Porsche 996 / 997 • SPEED READ: Porsche 911 Check out our new site: Dempsey Motorsports |
Good luck on fixing the problem
Alexander '75 911S Targa '86 951 SOLD |
Wayne,
Aren't you afraid of ruffling a lot of SCWD club members feathers. This coming from a guy still running tractor injection, but I agree that flapper doors are not conducive to max power.
Luke S. 72 RS spirit 2.7mfi, 73 3.2 Hotrod on steelies, 76 993 3.3efi TT, 86 trackrat, 91 C4s widebody,02 OLA winning 6GT2, 07 997TT, 72 914 v8,03 900 rwhp 996TT |
Unregistered
Say what you want, but my CIS works very well and doesn't catch my engine on fire
(ducking) |
