-   -   B&b Headers (http://forums.pelicanparts.com/porsche-911-technical-forum/236181-b-b-headers.html)
Dirkclod 08-15-2005 01:04 PM
B&b Headers
i just bought a 84 , 3.2 911 that has b&b headers and exaust. the set up is to loud till you hit 3000 rpm"s. can i change anything on this set-up to tone it down short of removeing headers ? it"s dual exaust and wondered if i cap of on side ? does any one know # for b&b ?? thanks for any help here and hope i am in right place.
JsGracey 08-15-2005 01:27 PM
1-888-228-7435
Try there 800 number
Dirkclod 08-15-2005 01:33 PM
Thank"S
cgarr 08-15-2005 01:41 PM
You can cap one side, its just a straight thru, that will make it much quieter, I have the single and its not bad, they say the dual adds nothing but noise.. What size tail pipes do you have? are they the oval 3"
Craig
Dirkclod 08-15-2005 01:42 PM
called and they said to block the left side by 50% and that would really help ???
Dirkclod 08-15-2005 01:45 PM
yes they are 3" craig. someone told me to cap off the right sidebut i don"t know if that would cause to much back preasure ?
cgarr 08-15-2005 01:53 PM
Yes you can also put in a restrictor, The single out which I have is the same as the dual out except the right side is not opened up, I was thinking about making mine a 2 out and open up the right side but I would need the tail pipe,,, just so I could piss off the hood!!
Craig
Dirkclod 08-15-2005 01:56 PM
Think i will try that. thanks for the help. Glad i found this site for i see it as being very helpful !!!!!!!!!!!
Dan Mc Intyre 08-15-2005 01:59 PM
You have no idea...yet.
Jim Garfield 08-15-2005 02:26 PM
I think that it's the right side that they recommend blocking off, and it does eliminate the 2-3k resonance.
Dirkclod 08-15-2005 02:30 PM
Right side from looking from back of car ??
Jim Garfield 08-15-2005 02:53 PM
Yes.
Dirkclod 08-15-2005 03:04 PM
Thanks, will post what happens. would like to put baffle in so i could open back up when i wanted.
Bill Verburg 08-15-2005 05:41 PM
Older B&Bs came w/ equal size outlets on both sides, newerr ones came w/ a very small(~.5") hole for the passenger size out. You don't see it because the tail pipe is normal size, the newest ones also have reinforcing ties to support the outlet stubs.
The small hole definitely reduced noise and resonance.
Kevin Stewart 08-15-2005 05:47 PM
I was having a NOISE problem also, set off car alarms as I drove by, I had a local shop make reducers that went down to 2.1/4 inch for like 6 inches then new tail pipes, it is a whole lot quieter, Jack O suggested it, I plan to keep the muffler now or untill it cracks, sounds really great even the wife likes the way it sounds, Kevin
Dirkclod 08-15-2005 06:07 PM
THAT IS WHAT I WANTED TO HEAR CAUSE THE WIFE IS WHERE THE NOISE PROPLEM STARTED. !!!!!!!!!!!!
Kevin Stewart 08-15-2005 06:09 PM
actualy they went down to 2 inches, Kevin
