Slide injection
Does anyone make aftermarket slide injection rather than ITB's\
Michael |
I'm not sure what's currently in production ... there are a couple of examples in bruce anderson's "911 performance handbook." I have heard that slides are not suitable for a street driven car, I think because the slides themselves get dirty and stick, someone should set me straight if they know better.
Cheers,
Andy |
Navin Johnson
Yes, but they are not mass produced like TWM, or Jenvey TBs, I have some links at my home computer.. Ill send later
oops Im surfing at work
Don't feed the trolls. Don't quote the trolls ![]() http://www.southshoreperformanceny.com '69 911 GT-5 '75 914 GT-3 and others |
I thought so too - but someone said they worked fine on the street. I think it might have Steve Wiener on Rennlist; but search there and here to see.
You could post your search results on this thread as a compilation.
"A man with his priorities so far out of whack doesn't deserve such a fine automobile." - Ferris Bueller's Day Off |
rennlist appears to be down right now, but especially if it was Steve's opinion, I would like to hear it.
Andy |
I think Andy is right about this one. If you like you can try Protechik in Stafford TX. They have made slides for a number of race cars.
-Jay '74 Mexico Blue 911 3.0 EFI (Fast and Loud) '70 914/6 Race Car (Faster and Louder) '71 73RSR tribute vintage race car 3.0 '68 SWB 911T "RENNRAT" 2.8 twin plug/915 gearbox '81 Magenta IROC clone in progress 3.6 varioram/G50 |
This is what I found on rennlist, not exactly what we were looking for but very interesting. I hope Steve Weiner does not mind me quoting him (steve, let me know and I will remove it if you want):
question was: what are the characteristics/advantages of 6 throttles. Quote:
Andy |
Crusty Conservative
Not a Porsche reference, but BMW M-Technik engines all have one butterfly per cylinder intake systems as part of their modification from the street equivalent.
Don't know that they have ever used slide valves, though... I think the Porsche slide valve system ($$$$) is available, or was not too long ago from Andial..
Bill 69 911 T Targa, 2.4E w/carbs (1985-2001) 70 911 S Coupe, 2nd owner (1989- 2015) 73 911 T Targa, 3.2 Motronic (2001- ) |
I'm no expert, but I don't see any reason why slide throttles wouldn't work great for street use. The reason that most street cars don't have them seems to be reliability. As was mentioned above, I've heard that they are prone to jamming from dirt in the slides. In a race car were the engine is removed and rebuilt every 50-100 hours (less for a Pro-Racing car), this isn't a big deal since everything is cleaned (if not rebuilt) between races and inspected multiple times in a season. Finally, if a throttle sticks, there is usually a kill switch near by.
Now picture a street car where things are put together and stay that way for many years and over 100K miles. The chances of having a throttle stuck open would seem to increase significantly. The results of having a throttle stuck wide open in a street car would not be pretty. BTW, "Barrel Throttles" seem to be more popular nowadays with the pro-race crowd. I believe that they provide the same WOT performance as slides, but may be less prone to jamming.
John '69 911E "It's a poor craftsman who blames their tools" -- Unknown "Any suspension -- no matter how poorly designed -- can be made to work reasonably well if you just stop it from moving." -- Colin Chapman |
Great points, John. I'm familiar with the barrel throttles but hadn't thought about them lately. Haven't seen any air-cooled porsche applications yet, though.
Andy |
Hi Andy:
LOL,.......I'm flattered that someone might quote me,... ![]() On the subject of slide-valve throttles; These can be quite reliable if good, effective aircleaners are used to prevent dirt from jamming the slides. These are close tolerance assemblies that are very prone to dirt making the sides not retract smoothly and that has VERY dire consequences. We have several street cars running RSR slide valves and with either K&N or ITG air cleaners, they have been very good. Barrel throttles need good air cleaners as well,....... The RSR slides are long out of production but Sam Shalala at ProTechnik made some awhile back and we have these on a 3.8 race motor. They are literally works of art but certainly not cheap.
Steve Weiner Rennsport Systems Portland Oregon (503) 244-0990 porsche@rennsportsystems.com www.rennsportsystems.com |
Do the slide valve make more power than a normal throttle body??
Michael |
Crusty Conservative
Slide valve works like a simple camera shutter. Hence, no obstructions in the air column. A good thing...;-)
Andy |
914-6 GT Resource Page
ANDIAL Slide-Valves
Well, since I did just purchased a set of the very rare ANDIAL slide-valves, I thought it would be appropriate to post a photo or two as well as the link to the photo gallery in my website.
http://www.pbase.com/9146gt/factory_racing_parts_911rsr_engine_slides_andial |
I made a slide valve for a 3-rotor Mazda engine so when Sam Shalala mentioned he makes one I had to see it. It's a very nice piece with very some good items that I'll incorporate into the next one I make. I didn't ask price, but I'm sure it's more than $3K a pair. The slide runs on bearings, I think Sam's uses Teflon balls. The balls are a little ways from the bore so dirt would have to get through some obstacles but it could get there, so a good filter is in order. I used round bores in the slide plate, but I've heard of some people using a D shape hole for a more linear throttle response. This might be better for the street. If I build a NA 911, I will definitely build a set of slide valves for it. It's not advisable for a turbo car, there's just too much pressure for the slide to overcome.
2014 Cayman S (track rat w/GT4 suspension) 1979 930 (475 rwhp at 0.95 bar) |
