leverpuller's Avatar
911 redline
when does the rev limiter kick-in on the 82 911 because I was half way in the red and nothing happened. No light, beep,or anything.?
Old 08-16-2005, 10:22 PM
82's rev limiter kicks in at when the first valve crashes into a piston.
Edward
993: retired Trackmeister, now daily driver heaven
911SC: resident Trackmeister-in-progress
Old 08-16-2005, 10:27 PM
thats what I thought
Old 08-16-2005, 10:28 PM
magic930's Avatar
There is also a blue light that comes on in your rear view mirror.
Old 08-16-2005, 10:47 PM
Early_S_Man's Avatar
Porsche Crest
Well, you didn't say whether it is a ROW or USA-spec car ... but, both had rev-limiters -- different types!
ROW -- rev-limiter rotor ...
USA -- speed switch cuts off fuel pump ...
Warren Hall, Jr.
1973 911S Targa ... 'Annie'
Old 08-16-2005, 10:50 PM
drag racing the short bus
dd74's Avatar
The rev limiter really kicks in when your wallet's empty.
Old 08-16-2005, 11:08 PM
durn for'ner
livi's Avatar
Interesting, Warren !
Why are there different types of rev-limiters ?
.... then there is the blue light coming on.... Fell off the chair!!
Markus
Resident Fluffer
Carrera '85
Old 08-17-2005, 12:32 AM
Bill Verburg's Avatar
It was felt that the fuel pump scheme rev limiter would be kinder to the catalytic converters on US cars.
Bill Verburg
Old 08-17-2005, 04:19 AM
Blanco's Avatar
Edward
1982 Porsche 911SC Coupe - Factory Short Shift |7:31 R&P in AL case | Toyo RA1 Tires | Corbeau TRS seats | M&K 2 in 2 out muffler
Old 08-17-2005, 04:53 AM
I like Orange
Cookie Porsche's Avatar
ROW - just check that dizzy rotor! I have seen a few cars fitted with a non-OE rotor that DID NOT have rev limiter...
I even saw someone 'modify' the rotor, supposedly for track use - so check your limiter!
BTW, reving the motor up in gear is normally safe (ish...) but miss a gear shift and none of the old factory rev-limiters will save you.
“Rules are meant to be interpreted…”
http://www.cafe9.co.za
Old 08-17-2005, 05:06 AM
jdowty3's Avatar
The fuel cut-off switch on my US 83 SC kicks in at just over 7K.
Jim Dowty
97 911 Coupe (Forest Green metalic, sunroof, leather)
PCA RSR region Insurance chair and Board member
Gruppe B #309
Old 08-17-2005, 05:25 AM
