-   -   Another CIS riddle solved, over lean condition (http://forums.pelicanparts.com/porsche-911-technical-forum/236748-another-cis-riddle-solved-over-lean-condition.html)
Scott R 08-18-2005 06:19 PM
For the archives and for anyone else that has this problem. After re-installing my motor, due to overwhelming oil/air leaks I had a bad drivability issue.
My 911 would start and run fine cold, and would run fine until I parked it to say go into a store. I would start it then after about 30min and it would not idle, it would just die. However it would run fine at or above 1k rpm's.
Solution, I was over lean according to my mechanics gas analyzer, I was a full percent too lean in fact. On my CIS system this equated to a quarter turn toward rich, with the O2 sensor disconnected. And then an adjustment of the idle set screw to get it where it was supposed to be.
Dave Taylor 08-18-2005 07:16 PM
Thanks, Scott. I'll file that away for the day my CIS pulls that on me.
Scott R 08-18-2005 07:38 PM
Exact numbers were 1.6 reduced to .06 for correct operation. (I just looked at the receipt)
Paulporsche 08-19-2005 07:31 AM
If those are your CO numbers, then going from 1.6% to .06% is actually leaner. Are you sure it wasn't .06 raised to 1.6?
BTW are you running a cat?
Scott R 08-19-2005 08:12 AM
Yes, I am running a CAT, I'll ask again today, I need to stop by there and get a part anyway. I think the receipt is backwards, since they were in kinda hurry.
