993 caliper tightening torque specs
I was hoping someone out there could help me... I am doing a brake job on a friends 993 (the cost of using borrowing the car for a DE weekend) and I need to know the torque specs for the caliper bolts. (both front and rear)
Thanks in advance,
Arnie
'87 Carrera
Old 08-15-2005, 08:36 PM
Senior Member
Leland Pate's Avatar
Let me go check my manuals... be right back.
Chief Architect and Mastermind,
SCWDP
Old 08-15-2005, 08:37 PM
Senior Member
Here ya go!!
85 nm or 63ft/lbs
SCWDP
Old 08-15-2005, 08:42 PM
Old 08-16-2005, 06:18 AM
Bill Verburg's Avatar
The factory recommends that the front bolts not be reused. Back it's OK
Bill Verburg
Old 08-16-2005, 06:21 AM
Forgo to ask, what is the torque for the rear caliper??
Thanks,
Arnie
Old 08-19-2005, 06:28 PM
rear is same as front, but can be reused
Bill Verburg
Old 08-19-2005, 06:35 PM
Silveresrty911S's Avatar
If your just doing pads there should be no need in removing the calipers.
This is something I've been studying on the 993's over at Rennlist. Is this true?
Rick
'76 Carrera 3.0, track
'77 3.2 targa, back home
'95 993 C4 M030, SOLD
PCA San Diego
Old 08-19-2005, 07:01 PM
Yes, it's true for both the front and back. If you are just changing out pads you undo the hold-down clips, disconnect the wear sensors at the strut and pull the pads out. You will have to spread the pads and get the pistons pushed back into the calipers before being able to pull them out. The rears are the same.
This works if you aren't having your rotors turned or replaced.
Old 08-20-2005, 03:24 AM
The answer is.. it depends
the Brembos used from 964 up come oem w/ anti squeel spyders that are glued solidly to the pads.
The spring side of the spyder clips into the pistons
Sometimes you can get a scraper between the pad and spyder to separate them, if you can then the pad can be removed w/o taking the caliper off it's mount, then the spyder can be removed as well.
But if you cannot, then the caliper will need to be unbolted. Not really a big deal either way.
Bill Verburg
Old 08-20-2005, 05:26 AM
