-   -   I have not posted a stupid question in a few days....European Racing Headers and fit. (http://forums.pelicanparts.com/porsche-911-technical-forum/236891-i-have-not-posted-stupid-question-few-days-european-racing-headers-fit.html)
jamesjedi 08-19-2005 04:54 PM
Hi all,
Will 2.7 liter, 1 5/8 European Racing headers fit a 3.2 . Is there any fit concerns, IE; the flange? Is this the best fit?
James
Carrera3.5L 08-19-2005 06:14 PM
Re: I have not posted a stupid question in a few days....European Racing Headers and fit.
Originally posted by jamesjedi
Hi all,
James
Not a dumb question IMO, I use George's 1 5/8" OD headers with 2" OD adaptors for a Dansk street muffler on my motor with no fitment issues. What do you mean by flange concerns?
http://forums.pelicanparts.com/uploa...1124500382.jpg
Are you going to be using adaptors/street muffler or straight megaphones out the back?
Ralph
Joe Bob 08-19-2005 06:24 PM
Unless you order them for street muffler use, they come shorter for proper fitting of "zoomies". Most people just use the add on pieces you see in the pics above.
Bill Verburg 08-19-2005 06:37 PM
good choice as long as you don't want heat
jamesjedi 08-19-2005 06:37 PM
What I am trying to figure out is...can I use the headers from a 2.7 that are 1 5/8 European Racing Headers for my 3.2? Are they identical headers? What I mean by "flange" is - where they bolt to the engine.
They will have megaphones (is that the same as zoomies?). As always, thank you for the insight.
James
Joe Bob 08-19-2005 06:39 PM
Depends on the pipe size...some people use 1.5 to 1 5/8 tubing on 2.7s....I used 1 5/8 on my 3,6...
Bill Verburg 08-19-2005 06:43 PM
Yes, the bolt pattern is the same for all 911s thru '94 964.
the Carrera has longer studs, change them or shim the nuts.
1 5/8" D is 1 1/2" ID one step up from SSIs
jamesjedi 08-19-2005 06:45 PM
They are 1 5/8 inside diameter. Would it simply bolt on to my 3.2 the same as they did for the 2.7 they were on? Maybe the 2.7 bolts...or exhausts ports are not the same as the 3.2.
James
Joe Bob 08-19-2005 06:46 PM
They fit...the late 3.6s are different....they angled them 180 off...
jamesjedi 08-19-2005 06:49 PM
Excellent! That is what I was hoping to here. Is the engine block the same size?
James
Bill Verburg 08-19-2005 07:53 PM
Yes:confused:
jamesjedi 08-20-2005 05:44 AM
Thanks. That will help a great deal.
James
