dorschman's Avatar
dark while driving- help
87 911 coupe- a few months ago the bright lights would come on spontaneously while driving with the low beams on. I could flick the bright/ flasher switch and they would go back to low beam. Annoying but manageable.
However, this has recently progressed to the brights not coming on when I flick the switch or worse (many back roads and deer) they will spontaneously cut off while driving, leaving me in the dark at 80 mph or so. Any ideas where to begin?
thanks
87 911 coupe "Katy"
Summer Yellow
Linen Mahogany interior
04 Pilot "The Pilot"
Old 08-19-2005, 05:45 PM
do you cary a flash light in the car?
Old 08-19-2005, 05:49 PM
GFCC
Jeff's Avatar
dorschman, I had the same problem. You need to take the steering wheel off and remove the turn signal stalk. You can replace it with a new one or do what I did and look inside of the switch while you move the lever from brights to low beam to flash brights. You need to see (It's been a few years since I did mine so I apologize for the non detailed directions) which way the metal pieces need to be bent to make contact when the switch is in it's appropriate position. The metal contacts get bent over time.
Jeff
1976 911 Coupe w/ Euro 3.0 - Sold
1987 Carrera Coupe - Sold
1999 Carrera Cabriolet - Current
Old 08-19-2005, 06:13 PM
dorschman's Avatar
thanks Jeff, we are planning to replace the steering wheel tomorrow so that sounds like the perfect time to assess the problem.
erik
87 911 coupe "Katy"
Summer Yellow
Old 08-19-2005, 06:21 PM
Make Bruins Great Again
Por_sha911's Avatar
Def the dimmer switch.
Joe
Old 08-19-2005, 08:36 PM
Dimmer switch.
I had the same symptoms on my '88 when I bought it.
GAD $24.95 on evilbay solved it.
Mike B.
'72 911E Coupe
Early "S" #1065
Old 08-19-2005, 08:53 PM
