Ring gear reversal
Anyone know if flipping the ring gear in a 915 transmission would give 1 forward and 5 reverse gears and that this would allow turning the engine/transmission 180 degrees (ie mid engined).
Has anyone done this or have any info on it?
Cheers
Tom
Tom
82 uprated 3.2L 911SC Coupe (Track Car)
Old 08-20-2005, 12:21 PM
Irrationally exuberant
ChrisBennet's Avatar
I wonder if using the tranmission upside-down would work? Obviously you need to make some mods either way.
-Chris
'80 911 Nogaro blue Phoenix!
'07 BMW 328i 245K miles!
Old 08-20-2005, 02:26 PM
125 shifter and 2.7 racerrecon that flipping the ring gear does it but it's a precise job. Any comments?
Tom
Old 08-21-2005, 03:18 AM
Geary's Avatar
It's pretty standard procedure for mid-engine applications. It's more time-consuming to check/set backlash, because the diff must be installed before the pinion shaft.
Old 08-21-2005, 11:17 AM
