Nitrometano's Avatar
Lay Shaft
Hi, how I can remove the lay shaft gear (intermediate shaft gear) from his shaft and sprockets?
1972 911T
1991 Mazda RX-7 Turbo II
Are you car loosing power? When was last time you service your fuel injectors? Dirty fuel injectors? Why no try a complete fuel injector cleaning service and return the dignity to you car. Visit www.rennsportfuel.com and we will return your injectors back to life!
Old 08-21-2005, 07:40 PM
Its been a while since I had to do this so Im a little fuzzy (had to swap a good gear from a bad shaft onto my good shaft w/ a bad gear)
I think you need to remove the chain sprockets first (look at which way the int gear has to go - it comes off in the direction of the bolt heads) . There is a large circlip if I remember correctly and the rest of the process was pretty straight forward w/ a gear puller. Remember to buy new lock tab washers for the gear.
SMD
Old 08-22-2005, 06:16 AM
I was trying with a 3 legs pulley but I notice that the sprockets can come easily. I need to use more force to get it out? I need to heat it?
1972 911T
Old 08-22-2005, 08:04 AM
Somatic Negative Optimist
Gunter's Avatar
Remove only one chain sprocket on the side where the bolt-heads are.
No heat, just a puller after the circlip is removed.
Remove the little Alu oil plug in the shaft before you use the puller otherwise it will get damaged. This Alu plug will have to come out anyway because you need to clean the inside of the shaft; there is a lot of dirt inside.
The big gear has a code: either "0" or "1", so, order the right one.
When reassembling, use new tab washers on the big gear.
To install the chain sprocket, heat it in the oven to about 250 first, put a little oil on the shaft seat and slide the sprocket on.
1980 Carrerarized SC with SS 3.2, LSD & Extras. SOLD!
1995 seafoam-green 993 C2, LSD, Sport seats.
Abstract Darwin Ipso Facto: "Life is evolutionary random and has no meaning as evidenced by 7 Billion paranoid talking monkeys with super-inflated egos and matching vanity worshipping illusionary Gods and Saviors ".
Old 08-22-2005, 10:22 AM
Thanks for the info, I will do that. If there is any extra information that I need to know, please share it. Thanks guys.
1972 911T
Old 08-22-2005, 04:39 PM
