Torsionbar advice (brands)
Hi
I have decided to upgrade my stock bars to solid 21/27. It seams overkill to go with hollow bars on a car that not going to be lightened. Our host only sells Sway-a-way, are they good? It says they manufacture the Weltmeister bars and I thought they had bad splines? So are Sway-A-Way equal/better/worse than for example Sander?
Magnus 911 Silver Targa -77, 3.2 -84 with custom ITBs and EFI. 911T Coupe -69, 3.6, G50, "RSR", track day. 924 -79 Rat Rod EFI/Turbo 375whp@1.85bar. 931 -79 under total restoration. |
Well, Sway-A-Way has been making torsion bars for a long time and for a variety of vehicles. Torsion bars aren't rocket science. You're not going to see dramatic performance differences between brands. I'm sure the Sanders bars are great, but Sway-A-Ways are fine, too.
I've had Sway-A-Ways in my car for ten years now... Mike
Mike 1976 Euro 911 3.2 w/10.3 compression & SSIs 22/29 torsions, 22/22 adjustable sways, Carrera brakes |
The sanders splines are rumored to fit the oem 911 mating pieces better, + hollow is "neat"
They should perform similarly. I went with Sanders because of the rumored poor spline quality of Swayaway. I hate to make buying decisions off of anectdotal information but then again I hate when stuff is billed as "bolt-on" and it's not.
'83 SC |
I will admit to having to spend about 5 minutes per bar with some emery paper to "take the edge" off of the splines to help the fit. Very minor "fitment" issue, all things considered.
Mike
You could think that a lesser quality spline could get stuck more easily in the future. Maybe I shouldn't´t worry
I bought a set of 31mm SAW bars a couple months ago. They fit perfectly the first time, and then immediately broke (both of them) when I set the car down off the lift. They sent me new bars and those work fine.
I just ordered up some 33mm bars, but I'm getting solid this time.
"You go to the track with the Porsche you have, not the Porsche you wish you had." '03 E46 M3 '57 356A Various VWs |
Where did they break? At the splines, in the middle, close to the spline...?
If it flows, it goes. If its smooth, it moves. Any questions? 96 993 C2 (Current) 87 911 Factory Turbo-Look Cab (Sold) 85 911 Factory Turbo-Look Targa (Gone) |
Me like track days
Elephant. Plated for corrosion -
- Craig 3.4L, SC heads, 964 cams, B&B headers, K27 HF ZC turbo, Ruf IC. WUR & RPM switch, IA fuel head, Zork, G50/50 5 speed. 438 RWHP / 413 RWTQ - "930 is the wild slut you sleep with who tries to kill you every time you "get it on" - Quote by Gabe Movie: 930 on the dyno |
The weight savings of the hollow bars needs to be put in perspective: The total wight difference between hollow and solid torsion bars for a 944 that I'm building right now was only 5 lbs (yes that is counting both bars, not each). The price difference between these solid and hollow bars is about $100. Now if you're building a super lightweight racer or have plenty of dough it may be worth it to you, but it probably isn't worth it for your average street car.
When I installed my Sway-A-Way bars last year, they popped right in without any filing. Works for me.
Eugene (Formerly) at Pelican Parts Pelican's E-Commerce Guy, 2003-2011 2001 330i Sport 1983 911SC Coupe (sold) |
I think I go with SAW and hope I don't get some duds like Thom. Craig, just visited Rennstore for the first time. Jesus, you don't hold back on the big letters, do you , I need a bigger screen!
A little more for Elephant now could actually save you money down the road when another type MAY rust.....IMHO
![]() I am going elephant when I can -Chris
1987 Guards Red Targa (sold) 2006 Toyota Tundra DC 4x4, the "man-e-van" 1998 CR500 Well on the fringe...... |
Me like track days
Save up. Get the stuff worth installing -
Well the spline quality concern on the SAWs is not just rumour. Mine where so bad on a set of hollow bars I sent them back - all the way across the Atlantic. Because of the taper on the splines you cannot just file or machine them down to size. If its just a light sand then fine, but mine were much worse than that. My mechanic and I could see no way of making them fit. The Sander bars that Pelican sourced as a replacement were, on the other hand, a perfect fit straight out of the box. My mechanic used to only buy oversized bars from Porsche Motorsport but was so impressed with the Sanders that he now has them in his own car.
Just my £0.02. Richard |
Eugene: Can Pelican source Sander bars?
They sourced them for me, partly because they sent me 915 29mm bars when I ordered G50 29mm bars and there were literally no SAW G50 29mm bars in the whole of the USA at the time available from *any* vendor. The only option was Sander bars.
Tom helped me out at the time - try a telephone call. |
A question if you don't mind.
Do the "spring rates" of the hollow bars differ from the solid ones? My 69 is riding high in the front...I need to lower it...but the adjustment screws do not have enough range. I know that I have to pull out the bars and rotate them to get better range. I am just thinking ahead to the possible problem of having to replace the bars at that time. Bob
Bob Hutson |
Mike
