-   -   Jacking up the front in the middle. (http://forums.pelicanparts.com/porsche-911-technical-forum/237947-jacking-up-front-middle.html)
on-ramp 08-26-2005 11:00 AM
any pics of car jacked up in the front, middle? all the a/c components have been removed.
I need to replace A-Arms, boths side and have to stabilize car. it's a 1983 sc .
thanks.
villaconn 08-26-2005 11:15 AM
Jack up one side. Put a jackstand under it. Go around the other side. Jack up and add another jackstand.
na2ub 08-26-2005 11:22 AM
You can put stands just behind the a-arms on the body, where the seam curves in and out. There is just enough room for a wood block to fit, with a stand supporting it.
Doug
einreb 08-26-2005 11:30 AM
2x4 cut to fit inside/between the a-arm front mounting points. jack up from the middle of the board. then put jackstands on either side of the jack at the ends of the 2x4.
LanceS4803 08-26-2005 12:38 PM
Does the chin spoiler allow enough room for the jack using the 2x4 method?
einreb 08-26-2005 12:41 PM
it does on mine. depends on your ride height and style of jack. roll the car onto 2x6's if you need some space
edward993 08-26-2005 02:40 PM
If the car is low, you've got no recourse but to jack a side at a time to get stands underneath for the front. I've got a low-profile alum jack and it still does not fit under the rubber chin spoiler (unless you allow the rubber to flex underneath it). But if all I want to do is get the front end on jackstands, I'll just jack up one side of the car with one jack just enough to get me clarance to then take another jack and raise the entire front of the car from the "beam-like" sheetmetal between the front mounts of the torsionbars. A hockey puck on the jackplate, center the pcuk, and the front comes up evenly and securely.
Edward
LanceS4803 08-26-2005 04:03 PM
I have a low profile jack also, and it is a REAL tight squeeze with the car being lowered and then the chin spoiler.
I think I will stick with the side lift and mount placement. Although, it still makes the car look like it is getting twisted when I leave just one stand under one side on the front before moving to the other side.
911mot 08-26-2005 04:16 PM
Talking of tight squeezes...
http://forums.pelicanparts.com/uploa...1125098162.jpg
DaveE 08-26-2005 06:01 PM
YIPES!!! How did you work on your car in there?
edward993 08-26-2005 06:53 PM
911mot wins! :)
Edward
LanceS4803 08-27-2005 12:27 PM
Man, that is a tight fit!
I won't complain about my garage space again.
naparsei 10-11-2005 07:28 PM
Assuming I am going to remove the entire front suspension, what's the best way to lift the car in front and get jack stands underneath (and where do they go?). I've read many, many posts on this, and I just don't quite get it.
Does "a-arm front mounting point" mean the torsion bar cover, in front on the belly pan? I have a '71T, and there is what looks like a factory tow hook right in the middle behind the spoiler. The idea is to cut a 2x4 to fit between the torsion bar covers? The picture of the underside of the car with jacking points (not with me now, but I have it at work) - that means running the 2x4 between both "A'" points?
I have seen a number people use jack stands with some kind of cushion at the "C" points, but it's not clear to me how you lift the whole front of the car and access those points.
I will try to post the picture I am referring to tomorrow.
Thanks,
Alex
rcecale 10-11-2005 07:47 PM
Work on it...?
How the he!! does he get in and out of the car while it's in there? That's what I'd like to know! :eek:
Randy
pwd72s 10-11-2005 08:26 PM
Goodness! All I can think of is you'd get in & out of the car when it's out of the garage...push or pull to get it in or out...Britland! I'll bet this garage worked well in it's original use...a horse stall.
randywebb 10-11-2005 10:48 PM
I bet you could squeeze out of the windows...
cantdrv55 10-11-2005 11:45 PM
Bet the car's a targa.
naparsei 10-12-2005 05:48 AM
Thanks,
Alex
Anyone? Bueller?
http://forums.pelicanparts.com/uploa...1129121283.jpg
einreb 10-12-2005 06:19 AM
my post on the 2x4 may only apply to later cars. :( for my '88, the board sits about midway up the letter 'A'. it fits between the gas tank and the front A/C condensor. Then the stands go just up from the 'A' arrows.
I'm not sure how much the tow hook sticks down, so I dont know what your jacking options are.
-Bernie
naparsei 10-12-2005 07:11 AM
Bernie,
Thanks for the quick response. The hook sticks forward, and not really down. You can actually see it in the picture above.
Anyone with an early car run the 2x4 between the "A" points and jack the jack up there?
einreb 10-12-2005 07:27 AM
mayby some 1X4's between the towhook and a-arm mounts... then a 2x4? I think the point is that you want to spread the load while jacking, and then support the car further out to make it stable.
Other option is to lift one side at a time with the jacking plate and lift the entire car. Then just put some blocks at the A arrows to spread the load when its on stands.
-Bernie
911pcars 10-12-2005 09:57 AM
If you're planning to R&R the front suspension, then you can't use the "A" area for jack stands. However, you can lift from there. For this operation, I'd support the vehicle with jack stands under a 2x4/2x6 spanned across the "C" dimension.
Since many cars are too low in front, lift one side from the jack receiver to get it high enough In order to roll your jack and a 2x4 under "A". I use a HF hydraulic scissors jack from the side (w/lift adapter) to gain height before using the floor jack.
Make sure the car is rock steady before you allow your body underneath. Redundant safety stands/jacks are good for one's confidence.
Hope this helps,
Sherwood
naparsei 10-12-2005 10:43 AM
Thanks Bernie and Sherwood. Appreciate the help. I will lift by "A" (with a 2x2 probably) then use a 2x4 or 2x6 + jackstands @ "C".
