-   -   CV Joint replacemrnt question (http://forums.pelicanparts.com/porsche-911-technical-forum/237978-cv-joint-replacemrnt-question.html)
Moke81 08-26-2005 02:58 PM
I'm thinking of going with the Lobro complete axel through our host. What else comes with the set? Can I use the excisting CV bolts? And do I need to use locking washers if there are none on the original ones?
Thanks in advance
Moke 81
1981 SC
cbeers 08-26-2005 04:04 PM
You SHOULD get all new hardware except for the spacer "plates" that act as washers for every two bolts.
At least, that's how mine came :)
-Chris
gatotom 08-26-2005 05:43 PM
when I did mine a few yrs back I had to get new bolts, the new units have smaller spacers thus needing smaller length bolts.
If your spacers on your car is the same as the new units, get new bolts anyway, good habit to replace bolts.
Grady Clay 08-26-2005 06:47 PM
Try this thread. It has everything you need to know and more.
http://forums.pelicanparts.com/porsche-911-technical-forum/222537-reconstructing-constant-velocity-cv-joints.html
Best,
Grady
Moke81 08-28-2005 02:26 PM
What size bolts do I need for them? are the lengths different for the new axels?
