Anyone ever seen a Bosch CDI like this?
It's a 3 pin unit, but I've never seen one like this.
Current: 1975 911S --Chocolate brown
Past:
1967 911S --Bahama Yellow
1990 C2 Targa --Silver
1973 914 2.0 --Delphi Green
Old 08-26-2005, 11:37 AM
Early_S_Man's Avatar
Porsche Crest
I doubt that it is a CDI ... probably an early - mid '60s 'Transistor Ignition.' I have seen similar units on several Porsche race cars of the period in Frere's books ... used external ballast resistors wound on balsa wood boards, wasn't an integrated system like the CDI.
Warren Hall, Jr.
1973 911S Targa ... 'Annie'
Old 08-26-2005, 11:49 AM
Kirk911SC's Avatar
Found this...............look 5 items down...............how's your Russian??
http://igishop.ru/details.php?cat_id=10346&sup_id%5B%5D=67&sup_id%5B%5D=30&sup_id%5B%5D=26
- '00 Dodge Viper GTS - Steel Grey - Yep...a domestic.
- '87 930 - Guards Red - Sold
- '82 911SC - Grand Prix White - Gone
- '78 928 - Silver - Long gone
- '04 Subaru WRX wagon - Sold
Old 08-26-2005, 11:57 AM
Says "Switchboard, ignition system"
Warren & Ron, may you rest in Peace.
Old 08-26-2005, 12:03 PM
Kirk911SC's Avatar
Guess I should have used a translation program 1st!
Babel fish
Old 08-26-2005, 12:05 PM
Wow! Well this is what's running in my 67S, and I had just assumed it was one of the M&W CDI boxes untill I removed it and found the Bosch markings.
That answers some strange problems I had with a bosch blue coil. In the pic I replaced the larger blue coil with the smaller one and the car wouldn't idle at anything less than 15 degrees advance and wouldn't rev past 4500. So I put the old (big blue) coil back in, but as a backup I purchased a black (CDI) coil.
I'm now guessing that's not going to work?!
So what the hell is this big blue coil, something special for this type of ignition? Or is it possible that my smaller new blue coil is just a bad unit..
Help!!
Past:
Old 08-26-2005, 12:06 PM
304065's Avatar
Actually, it says,
Commutator, sistema zazhiganiya.
зажигания is ignition.
One remnant of growing up in the cold war is that I can still read cyrillic.
Doesn't look to be a VW, Benz, BMW or Volvo part. Who else used bosch as a supplier? NSU?
'66 911 #304065 Irischgruen
‘96 993 Carrera 2 Polarsilber
'81 R65
Ex-'88 Carrera (Sold 3/29/02)
Old 08-26-2005, 12:20 PM
Porsche Crest
Retro,
What are the Bosch part numbers stamped on the bottom of the cans? Measure the primary and secondary winding resistances of the two coils, and maybe you will have an answer.
A CDI coil will definitely not work! It doesn't have enough inductance to operate correctly, and would overload the driver transistor, and probably overheat, and maybe even burn out the driver transistor!
My suggestion is to yank all of that cobbled wiring and replace it with the simple CDI system, since you already seem to have the parts for the conversion ...
Warren Hall, Jr.
Old 08-26-2005, 12:21 PM
Yeah, I just need the 3 pin harness for the CDI box.. the one off this transistor deal won't fit, then I'll swap it out.
The newer small blue coil numbers are 0 221 119 027 and 9 220 081 083 and reads 3.9 ohms
The old larger blue coil has 0 221 118 003 and reads .8 ohms between the posts
Past:
Old 08-26-2005, 02:45 PM
Well, it appears this big blue coil is something specific to this transistor garbage.
It's 1-15 resistance is the same as my black coil at .8 ohms, but the # 4 post to the 1 is 10,900 ohms.. where my black coil is 710.
Past:
Old 08-26-2005, 03:38 PM
Lorenfb's Avatar
That ignition unit is a TCI (transistor coil ignition) as mentioned by Warren
and very similiar to ones used on the 917, which were not CDI types.
"Well, it appears this big blue coil is something specific to this transistor garbage." - RetroSC -
What do you think ALL late model OEM engines use, i.e. TCI systems?
Have Fun
Loren
Systems Consulting
Automotive Electronics
'88 911 3.2
'04 GSXR1000
'01 Ducati 996
'03 BMW BCR - Gone
Old 08-26-2005, 07:16 PM
