-   -   Just installed Bilstein inserts in Boge (http://forums.pelicanparts.com/porsche-911-technical-forum/238078-just-installed-bilstein-inserts-boge.html)
rfuerst911sc 08-27-2005 10:40 AM
Well I have had a set of Bilstein HD inserts sitting in the garage for about 6 months just never had time to get to it. I had done my usual amount of research on what had to be done and today I decided to do it. I can't believe how easy this was. From start to finish it took me just under 2 hours total for both sides. Everything removed easily and went back together just fine. I did the "tilt" method rather than removing the strut housing. My 83SC now has fresh Bilstein Sports in the rear and HD up front. Next will be replacing my 20/18mm sway bars with 22/21mm which will be happening next month. Well I'm off for a spirited jaunt!!SmileWavy
450knotOffice 08-27-2005 11:07 AM
Excellent! I'm sure the car feels much better now.
Have fun with the sway bars. They're a pain in the arse.
HardDrive 08-27-2005 11:17 AM
Cool. I am looking at doing the same job in a month or so.
mmastro 08-27-2005 12:00 PM
Rick,
I'll be shipping the 22mm swaybar next week, just as soon as I receive the funds.
What size torsions are you running front/rear?
It's neat to hear that you're making strides on the suspension upgrades!
Cheers,
rfuerst911sc 08-27-2005 02:41 PM
My torsion bars are stock for now. I thought I would upgrade shocks and sways first and then torsion bars after I get some seat time. After taking the car for a spin today it really feels much better than the 108,000 mile Boges they replaced. MMastro I was hoping the funds would have been there today but apparently not. That's O.K. as I have time and when I receive the bar I will clean and paint it before installing.
mmastro 08-27-2005 10:37 PM
Rick,
Check arrived today! bar/bushings will go out monday on my lunch hour.
Mike
azasadny 08-28-2005 07:59 AM
Good job! I'll be doing the same project this fall except that I'm using Boge struts in the front.
Seeeu911 08-28-2005 08:23 AM
rfuerst911sc...dude why are you having all the fun by yourself ? PM me and I can lend a wrench on your bar bushing install. It will be practice for mine next.
rfuerst911sc 08-28-2005 08:34 AM
Seeeu911 PM has been sent I can use the help.
