Gon fix it with me hammer
mfi shutoff with msd tach ??
how do most people deal with the shutoff relay
when they install MSD ignition?? obsolete it or is there a way to trigger the relay from the MSD tach???
Stijn Vandamme EX911STARGA73EX92477EX94484EX944S8890MPHPINBALLMACHINEAKAEX987C2007 BIMDIESELBMW116D2019 |
The RPM transducer(speed Switch) needs a RPM signal. It usually gets it from the CDI from the same wire that goes to the distributer. With the MSD you do not have this signal wire anymore. On my 69 I ran the tach output of the MSD to the RPM transducer rpm signal(black/purple wire). It worked. I measured the voltage output to the micro switch and it is on (12 volts)over 1500 Rpm and shuts off at 1300 Rpm. Try it. I bet it works.
69 911 2.3Ez 85 928S |
cool, thanks, wasn't sure if the transducer and the msd were compabitle
it's been a while, but finally got it hooked up like you described... works like a charm...
I found it very useful to have a manual over-ride switch for the shut off solenoid, especially when the car was cold. The solenoid tended to cut off the engine when cold. I connected the manual over-ride across the microswitch. This may not be relavent to your conditions, but thought it useful to consider.
I incorporated the switch in a little control/LED monitoring box attached underneath the ashtray. Sorry dont have pics, car in workshops.
POKDUB Porsche 911E |
Yep, the MSD tach driver is a square wave, works perfectly.
'66 911 #304065 Irischgruen ‘96 993 Carrera 2 Polarsilber '81 R65 Ex-'71 911 PCA C-Stock Club Racer #806 (Sold 5/15/13) Ex-'88 Carrera (Sold 3/29/02) Ex-'91 Carrera 2 Cabriolet (Sold 8/20/04) Ex-'89 944 Turbo S (Sold 8/21/20) |
