WydRyd's Avatar
Question Remove Oil Cap - Idle remains stable!
Gents,
I thought when you remove the oil cap to check the oil level, the engine idle should drop (or dip) 100-200 RPM's. Mine does not seem to do this The idle remains rock steady!
Does this mean I have a big gaping vacuum leak somewhere?
I checked as many of the vacuum hoses around the intake and oil filler neck and they look fine
What else can I check?
I'm thinking perhaps:-
1. Checking and re-torquing the intake manifold bolts - What torque setting should I use?
2. Checking & tightening the rubber boot that joins the left and right "hemisphere" of the intake manifold?
Anything else?
P.S: I also noticed a white'ish/orange'ish foam residue under my oil cap. Is this something to worry about, or is it just moisture/condensation? It's been pretty cold down here lately, so I'm hoping the latter!
Merv
'89 911 Turbo Cab
Protomotive MAP ECU, Twin Plugged Heads, GT2-EVO CAMs, 3.3L fully finned P&C's, ARP fasteners, C2T head gaskets, Titanium Retainers, Turbo spec valves, springs & guides, 964 splash valves, GT35R BB turbo, GSF Stainless Headers, Magnaflow Exhaust, Full bay Intercooler, TiAL 46mm w/gate, TiAL 50mm BOV, Apexi AVC-R EBC, SPEC Stage3+ Clutch kit, Crane CDI Ignition
Old 08-29-2005, 01:22 AM
safe's Avatar
Mine doesnīt drop either. I donīt have any vacuum leak.
Magnus
Old 08-29-2005, 03:45 AM
Wider is Better
wholberg's Avatar
Same here.
Wider is Better
Old 08-29-2005, 04:40 AM
Irrationally exuberant
ChrisBennet's Avatar
It means your idle stabilizer is doing it's job and the breather hose restrictor is in place.
-Chris
'80 911 Nogaro blue Phoenix!
'07 BMW 328i 245K miles!
Old 08-29-2005, 05:42 AM
kqw kqw is offline
You are correct....there should be a drop in idle when removing the oil filler cap.
Looks like you are on the right track. The intake manifold bolts should be torqued to 18 ft/lbs. Make sure you get to all 12 bolts.
As Chris mentions...check the restrictor valve, make sure it is positioned correctly.
The Fox
Carrera
Old 08-29-2005, 07:22 AM
read Tyson's comment
Engine died while checking oil and other Q's
Old 08-29-2005, 07:45 AM
