Backfire after tune-up
HELP! I replaced my point/cap/rotor over the wekkend and after installation my car does not start and backfires very very loud.........I put the wires the right way....what can be wrong?
Thanks 73 911T |
Friend of Warren
Did you remove the distributor? If not then recheck your points gap and even though you think the wires are on correctly, double, no triple check. Make sure when the engine is at Z1 that the rotor is pointing at #1 on the distributor cap and that the #1 wire is in the right place.
Kurt V No more Porsches, but a revolving number of motorcycles. |
Double Trouble
Sounds like you got a wire mixed up to me. Check it again.
I used to be addicted to the hokey pokey..........but I turned myself around.. 75 914 1.8 2010 Cayenne base |
Make sure the spring loaded center metal sprong inside the distributor cap did not get wedged/crambed all the way up, and freely moves so it may apply pressure to the top of the rotor.
1977 911S Targa 2.7L (CIS) Silver/Black 2012 Infiniti G37X Coupe (AWD) 3.7L Black on Black 1989 modified Scat II HP Hovercraft George, Architect |
