-   -   Casting material (http://forums.pelicanparts.com/porsche-911-technical-forum/238314-casting-material.html)
project 911 08-29-2005 05:12 AM
Casting material
Does anyone know of any product you could use to cast small parts originally made from Bakelite? Something with some strength that would take higher temps.
Just wondering...
69911e 08-29-2005 05:26 AM
If it is ok to be conductive metal you could get a simple sand-casting kit used to make jewelry(I think mine was less than $50). The casting grains are very inexpensive.
RickM 08-29-2005 06:36 AM
Steve,
This thread may help http://forums.pelicanparts.com/porsche-911-technical-forum/140069-diy-plastic-molding-possible.html?highlight=cast
project 911 08-29-2005 06:52 AM
It does have to be non-conductive. Should have said that.
David 08-29-2005 06:54 AM
Devcon makes liquid plastic.
project 911 08-29-2005 07:01 AM
Does anyone know if fiberglass resin can take any heat. I'm thinking specifically of reproducing Beru connector tubes. I was wondering about tiger hair???
David 08-29-2005 10:38 AM
Fiberglass resin, at least the boat stuff I've used, is very brittle. The Devcon stuff is very good, we use it at work. You can use it to make molds and then with a release agent you can make parts in the molds.
