CIS Injector Tubing Specs
I need to replace some of the tubing on my CIS.
Does anyone know the specs for the tubing: ID, OD, wall thickness, temperature and pressure ranges. I plan to use nylon 6. Nylon 11 seems to be a little soft . Any ideas or suggestions? Any help will be appreciated. |
Search button is your friend.
Try nylon CIS as search terms. As a clue, Jim Sims has a great post on the topic. |
Beware of using aftermarket CIS tube.....I used McMaster Carr tubing and suffered a misfire that took me 6 months to figure out that the tubes were the issue.
See this thread for the full story: http://forums.pelicanparts.com/porsche-911-technical-forum/236328-cis-misfire.html |
Jim, my OEM tube is more like 8mm with a 3mm wall thickness (i.e. a relatively small flow area).
Note, I'm still looking for a supply of correct fuel line, my original lines definitely need changing. Thanks, Stu |
The pulsation was much faster than that expected from WUR. Something around 10Hz at idle, getting faster with higher fuel flow. I used the exact fuel lines you specified. And just in case you're wondering, no, I don't blame you. These things happen. |
| All times are GMT -8. The time now is 06:11 PM. |
