CIS Injector Tubing Specs
I need to replace some of the tubing on my CIS.
Does anyone know the specs for the tubing: ID, OD, wall thickness, temperature and pressure ranges. I plan to use nylon 6. Nylon 11 seems to be a little soft . Any ideas or suggestions? Any help will be appreciated.
HBF |
Search button is your friend.
Try nylon CIS as search terms. As a clue, Jim Sims has a great post on the topic.
Beware of using aftermarket CIS tube.....I used McMaster Carr tubing and suffered a misfire that took me 6 months to figure out that the tubes were the issue.
See this thread for the full story: CIS misfire |
Jim, my OEM tube is more like 8mm with a 3mm wall thickness (i.e. a relatively small flow area).
Note, I'm still looking for a supply of correct fuel line, my original lines definitely need changing. Thanks, Stu |
Who is John Galt?
The pulsation was much faster than that expected from WUR. Something around 10Hz at idle, getting faster with higher fuel flow. I used the exact fuel lines you specified. And just in case you're wondering, no, I don't blame you. These things happen.
'79 911sc Targa '02 slk230 kompressor '84 Tamiya Falcon A democracy cannot exist as a permanent form of government. It can only exist until the voters discover that they can vote themselves largesse from the public treasury. From that moment on, the majority always votes for the candidates promising the most benefits from the public treasury with the result that a democracy always collapses over loose fiscal policy, always followed by a dictatorship. The average age of the world's greatest civilizations has been 200 years. |
