O2 Sensor Help !!
What are the signs when O 2 sensor is malfunctioning ?
Thanks again Vinnie in Ventura 1989 911 Silver Anniversary |
Disconnect it, see if the problem goes away. If it does.. chances are the O2 sensor is bad. :-)
Paul 2001 CLK55 AMG, 1987 911 Turbo Look, 1997 Viper GTS. |
Dumb Question . Where is located in my car ?
Thanks |
GFCC
The top of the catalytic converter.
Jeff 1976 911 Coupe w/ Euro 3.0 - Sold 1987 Carrera Coupe - Sold 1999 Carrera Cabriolet - Current |
Thanks Jeff ,
will it damage my car to run it without the sensor? Jeff is it Hot in AZ ? It is 74 degrees in ventura and I have a sweater on in the office . Thanks Again , Vince |
GFCC
Vince it won't run as good. This is an input sensor for the DME/ fuel injection system. It tells the computer how rich or lean to make the gas / fuel mixture.
And yes it's HOT! I just fertilized my postage sized yard and am sweating my a$$ off.
So Jeff ,
now I am confused . Ewave tells me to disconnect and if the problem goes away its the sensor . You tell me that if I disconnect the sensor the car will run bad anyway . Vince |
GFCC
Vince, the car won't run at it's optimal level without the O2 sensor. May run rich or lean at different load/ rpm ranges. I have heard of people testing their O2 sensors the way Ewave states but have never done it personally. The Bentley manual says to test the O2 sensor you need to use a pinout test harness at the DME and test fluctuations in voltage out put of the sensor.
The DME only relies on input from the O2 Sensor at Idle, or part throttle (<60% throttle). I believe with the O2 sensor in circuit, the DME aims to maintain a 14.x:1 A/F ratio at idle and part throttle.
If you disconnect the O2 sensor from the DME, it will richen the idle and part throttle mixture & adversely affect your mileage too.
Merv '89 911 Turbo Cab Protomotive MAP ECU, Twin Plugged Heads, GT2-EVO CAMs, 3.3L fully finned P&C's, ARP fasteners, C2T head gaskets, Titanium Retainers, Turbo spec valves, springs & guides, 964 splash valves, GT35R BB turbo, GSF Stainless Headers, Magnaflow Exhaust, Full bay Intercooler, TiAL 46mm w/gate, TiAL 50mm BOV, Apexi AVC-R EBC, SPEC Stage3+ Clutch kit, Crane CDI Ignition
