msk1986911's Avatar
Power Seats
Does anyone have any suggestions for troubleshooting power seats in a 1986 911? The front adjustment works intermittently while the rear adjustment (for the seat base) does not work at all. I pulled the seat and could find no obvious loose wires, although the mechanism for the rear seat control does appear to bind.
Any help will be appreciated.
Old 10-06-2005, 07:26 PM
Don Plumley's Avatar
Likely a broken switch. Mine did a very similar thing - intermittent, then died. When I took the switch out, the inside exploded. Unfortunately the replacement was a little pricey.
Don Plumley
M235i
Old 10-06-2005, 07:33 PM
Ditto, mine were corroded on the contacts on the inside. Apparently it is possilbe to take them apart, clean them, and put them back together. I broke mine putting it back together. I ended up using these:
http://www.itcelectronics.com/pdtl.asp?P=3498
mounted in a peice of sheet metal in the place of the OEM switches. harder to connect, but can't beat the price.
jason
motors: 73.5 911 T targa - RIP, 2005 Subaru Legacy 2.5i
pedals: Ellsworth Truth, Neuvation road bike
Paddles: Dagger Ego
Wind: Liquid Force kites/Ocean Rodeo Mako board
Old 10-06-2005, 10:13 PM
MAGA
Tim Hancock's Avatar
My switches needed cleaning in two different sets of seats I have had. Be careful prying them apart and be prepared for little parts to fall out as it comes apart. Take your time and they will go back together and work fine.
German autos: '79 911 SC, '87 951, '03 330i, '08 Cayenne, '13 Cayenne
0% Liberal
Men do not quit playing because they get old.... They get old because they quit playing.
Old 10-07-2005, 04:26 AM
msk1986911's Avatar
Power Seats
Thanks for the prompt response. I hope that cleaning the switch will do the trick.
Old 10-07-2005, 03:55 PM
