Highfield's Avatar
73T - Rear Banana Arm Reassembly
Whilst the weather had brightened up, and it was already too late to head to Castle Hedingham, I decided to make a start on reassembling the aluminium banana arms that had been cleaned by me and then fitted with new bearings and the hub pressed in at Tuthills.
The emergency / handbrake assembly has already been cleaned, so it is just a case as Haynes would say of "reassembly is the reverse of the disassembly" :-)
Here are the parts required - note that I am missing three of the pins that push through from the rear of the brake plate and have the springs attached to them to keep the shoes in place - if you have any of these spare then please let me know.
The parts go back together easily when they are clean and can be handled, but just remember to get the collar that fits over the spring that holds the brake shoes in place the right way round - i.e. the bell shape pointing inwards :-)
Next up I loose fitted the brand new Carrera 3.2 disk from Sebro (?) and the backing plate.
The final piece to be fitted was the Elephant Racing Monoball and Wevo E-Z Pins - heat the arm in boling water and press fit. I used a combination of clamps and sockets to squeeze it in as I do not own a press - a bit Heath Robinson but it worked.
Just the other arm to do and they are ready for fitting.
Ian
Ian Highfield
1992 964 C2 Manual with RS Suspension etc.
1973 911T Narrow body Hot Rod with 2.7 Carrera engine and loads of period modsl - SOLD
1986 Carrera Coupe Sport with Stainless Silencer and SW Chip (256 fwbhp) - SOLD
Old 06-07-2009, 10:31 AM
Chuck Moreland's Avatar
Ian
The rear monoball is not fully seated. You can see the gap between the shoulder and the arm here:
That is why your snap ring isn't closing up the way it should.
When you press the monoball in, be sure you are putting the load on the outer housing and not the center or spacer.
Chuck Moreland - elephantracing.com - vonnen.com
Old 06-07-2009, 02:41 PM
