RSR style roll bar fit...is it to far forward?
Just installed an RSR-like bar. Is it to close to the seat? Is this goofy?! I Know that a DAS, Safety Systems etc. , would have a much better fit I guess I like the old style....sort of a back date for my 84.
http://forums.pelicanparts.com/uploa...1125592388.jpg [img]http://forums.pelicanparts.com/uploa...1125592574.jpg |
something doesn't look right.. they normlly run in line with the door window frame....it looks like it is leaning forward a bit..
It does lean a littleforward, I was told that was for "deflection", does that make any sense?
Here are the only two pictures I have found that would even come close to showing the angle one should sit at.. hope it helps..
http://forums.pelicanparts.com/uploa...1125593265.jpg http://forums.pelicanparts.com/uploa...1125593284.jpg |
Seems to me that yours may be a Cab roll bar and not one for a coupe. I have a DAS bar and it follows the pillars very closely.
I know that DAS is a super fit. But will this work? This is a weekender car....a pretend race car, or occasional track car. Will it work?
| All times are GMT -8. The time now is 03:31 PM. |
