early 911 rear pics
Hello
May you post pics of the early style rear panel location for my retoration please close pics appreciated Best regards Philippe (RS73 touring replica) |
nobody to help me to rebuild the rear central panel with bumpers.?
not sure what you want
"A man with his priorities so far out of whack doesn't deserve such a fine automobile." - Ferris Bueller's Day Off |
RETIRED
Best to post pics of what you have.....
1983/3.6, backdate to long hood 2012 ML350 3.0 Turbo Diesel |
Bonjour, Philippe.
Is this the panel you want to see?
techweenie | techweenie.com Marketing Consultant (expensive!) 1969 coupe hot rod 2016 Tesla Model S dd/parts fetcher |
<insert witty title here>
![]() (And that's when the garage was clean! )
Current: 1987 911 cabrio Past: 1972 911t 3.0, 1986 911, 1983 944, 1999 Boxster |
This is a real RS lightweight:
I got this one without the bumpers.
-Britain
'69 912 w/ 2.3L Type-4 Turbo Engine '74 914 1825lbs, JDM Subaru STi Spec-C Engine, Lotus Suspension, 930 Trans. '80 924 AAN 5-Cyl, Corvette C5 Transaxle - Team UBoot Rennwerks -- www.britainracing.com -- |
starts good
closer with open deck ? |
This is the best I've got. From my '72 911T. Hope it helps.
Doug Currently Between Porsches PART OF MY SOUL: '09 Boxster 2.9 PDK, '86 911, '76 912E, '06 Cayman S, '90 911 C4, '74 911, '78 911 Targa, '01 Boxster, '70 911T, '99 Boxster (#2), '72 911T, '88 911, '99 Boxster (#1), '84 911 Turbo Look, '73 911 Targa, '88 944 |
what are you after?
note the twin plug covers for each bumperette in the pic above - there are 2 Allen drive bolts in there & 1 below (or is it 2?) - best to put all of them in loosely and then tighten the center panel has slots that slide over the bosses that the bolts go into post if you want a pic of that - I'm going out to the paint shop later this week and can take a pic if you need it. BTW - I have an Email in to Restoration Designs asking for the wt. of their Al panel. The real wt. saver is all FG back there.
Useful info, Randy.
Philippe, the licesne plate panel has two gaskets -- one looks like this: _\|/_ and goes against the body. The other is visible on the orange car above: it has slots for the license lights to shine through. The bumperettes each have one gasket against the license plate panel.
that's ok
thanks Doug |
